Sump Pump In Crawl Spae - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2016, 09:37 AM   #1
retired guy
igneous's Avatar
Rewards Points: 143
Sump pump in crawl spae
I live in NC. I had trouble with moisture in crawl space, and have since installed a sump pump. The discharge is through the block wall at ground level. Since there is a swale between my neighbor's house and mine, the ground is very soggy. I would like to change the discharge so the water goes into the down pipe under the kitchen sink. A simple T joint and rerouting of pipes looks like the solution. Does this sound like a reasonable solution?
igneous is offline   Reply With Quote
Old 01-03-2016, 09:50 AM   #2
Rewards Points: 3,220
You can't tie ground water into your municipal sewer at my location, I don't know about nc.
Best to call your local municipality to make sure, if thats what you plan on doing.
jmon is offline   Reply With Quote
Old 01-03-2016, 01:58 PM   #3
Rewards Points: 352
Bad idea if on septic, usually illegal on city sewer. How about piping it away from house into a large drywell or to where it will naturally drain away from house.
plumberinlaw is offline   Reply With Quote
Old 01-03-2016, 02:24 PM   #4
Rewards Points: 3,286
Where does the swale go to?
A swale is intended to receive and collect water.
While a sump pump can have an underground pipe to a dry well, freezing of the pipe in winter can be a problem.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 01-03-2016, 02:34 PM   #5
Rewards Points: 127
In our locale it has to be piped to a dry well, surface or to a storm drain. I can not be pumped into the sanitary sewer. You will need to check with your local authorities. If you are in a septic tank it's it a quick and sure fire way to destroy your septic system.
jimn01 is offline   Reply With Quote
Old 01-03-2016, 10:02 PM   #6
Rewards Points: 352
http://www.ask.com/geography/frost-l...d6f3a655159b72
Help with Sump Pump Issue (Drainage as well) neverlandpirate Plumbing 2 12-30-2015 07:57 AM
Sump Pump install in crawl space dann0187 General DIY Discussions 3 12-15-2015 08:31 AM
Sump Pump Pit Alicea21 Plumbing 2 09-28-2014 08:31 AM
1 Sump Pump No Longer Running, The Other Now Runs Majority of Time PolishPete Building & Construction 8 06-14-2014 03:46 AM
Sump pump drain into buried downspouts Chokingdogs Plumbing 1 11-07-2012 11:09 AM
