Sump Pump Check Valve Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2015, 10:43 PM   #1
Rewards Points: 2
Sump pump check valve help
We just purchased a new home and the sump pump check valve is making a horrible noise when it runs. The discharge is offset from the pump and there is a vent of sorts that runs to the floor drain. I have never seen this setup before. We are in Dupage county Illinois, but I don't believe this is a code issue. Any suggestions on the install or recommendations on the check valve would be appreciated. Thank you!
carbocaine is offline   Reply With Quote
Old 12-13-2015, 11:51 PM   #2
Rewards Points: 276
Could just need a cleaning.
throrope is offline   Reply With Quote
Old 12-14-2015, 06:30 AM   #3
Rewards Points: 127
Sump pump check valves only cost a few dollars. Get a new one.
jimn01 is offline   Reply With Quote
slamming check valve on basement ejection pump crankcase Plumbing 4 12-04-2011 08:38 PM
Help with check valve on recirculating pump joeq Plumbing 21 10-08-2011 04:24 PM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 06:51 PM
Loud sump check valve BlueBSH Plumbing 1 01-19-2010 04:14 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
