Sump Pump Cables - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2016, 09:50 AM   #1
Rewards Points: 18
Sump pump cables
Hello experts!
Previous Owner set up sump pump with battery backup pump. There are a lot of cables: AC, batter power, backup switch, backup sensor. There's a lot of slack in most of these cables.
For some reason, PO put most of this slack inside the pump. That made a rat's nest of cable that leads to the float switch being trapped from above or below if any of the cables get moved by just a bit.
Is there any good reason to put the slack in the sump, and not on the floor surrounding it?
Thank you.
pnorman55 is offline   Reply With Quote
Old 05-14-2016, 06:15 PM   #2
Rewards Points: 18
Re: Sump pump cables
"For some reason, PO put most of this slack inside the pump."
Haha - that should read "inside the sump"...
Old 05-14-2016, 07:26 PM   #3
Rewards Points: 286
Previous owner most likely didn't like them visually lying around, but I agree why not just limit the inside to the mandatory ones and lessen the slack on the others outside the sump. I have two cables exiting my sump lid; the rest are adjoining the back up system neatly dealt with. Remember to get your back-up battery off the floor (piece of wood under it is sufficient) and to check it's function once in a while to ensure it's working. I find our 1 year old boat-like battery that came with the system gradually discharges over the months, even with adding distilled water and despite the indicator reading active.Most back up batteries are only good for 3 to 6 hours depending on rain volume/intensity. Enjoy your new home.
ProGreen is offline   Reply With Quote
Tags
pump , sump , sump pump
Sump Pump Backup System steve-19 Plumbing 1 01-18-2013 12:15 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
