Sump Pump Battery - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2016, 09:59 AM   #1
Rewards Points: 818
Sump Pump Battery
Last night our sump pump backup battery alarm went off and I think the battery might be dead. Its several years old and has had to kick on quite a bit. Before I get a whole new back up system, I wanted to try just a new battery first.
Do I need to get a battery specifically for sump pumps (i.e. watchdog, wayne, barracuda, etc.) or I can I get a marine grade or deep cycle battery? Seems like the cost is double for a sump pump battery.
cibula11 is offline   Reply With Quote
Old 02-11-2016, 10:06 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
no, just go on ebay and put the battery model in and a new one should pop up...what voltage is that battery?
WhatRnsdownhill is offline   Reply With Quote
Old 02-11-2016, 10:22 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,614
Any deep cycle battery should be fine, marine or RV.
What is name etc. on the existing battery?
The Following User Says Thank You to joed For This Useful Post:
Nick DIY (02-11-2016)
Old 02-11-2016, 10:35 AM   #4
Rewards Points: 818
Pretty sure its a watchdog. Not sure what the amperage is, as Im not looking at it now, but its fairly large battery. Is there a certain size I should be looking for? My local big box store has 4 different types of marine grade batteries.
I think mine might be like this one: http://www.homedepot.com/p/Big-Stand...140S/100054931
So I could probably use something like this?:https://www.menards.com/main/tools-h...32168499313461
Old 02-11-2016, 10:42 AM   #5
Rewards Points: 6
You may also want to purchase an inverter just as a backup. It will charge the battery and be available when the battery dies as an additional backup.
JoeNewFramer is offline   Reply With Quote
Old 02-11-2016, 10:53 AM   #6
Rewards Points: 459
I just installed a Wayne sump package with a 2nd pump on battery backup. It has a built in charger.
The battery is a common Group 27 deep cycle battery. A group 27 is about 12" x 6" x 9". If it's only about 10" wide, it's probably a common Group 24 battery. You should be able to get either anywhere that Marine/RV batteries are sold including Walmart, Kmart and auto parts stores.
Nick DIY is offline   Reply With Quote
Old 02-11-2016, 11:25 AM   #7
Rewards Points: 818
Thanks. I think I have a smaller one which the previous HO left behind. That one is probably a group 24.
Will there be any problem using the watchdog alarm if I hook up to a marine grade battery (not watchdog battery)?
Old 02-11-2016, 11:32 AM   #8
Rewards Points: 459
Just look for 12VDC on the motor, controller or owners manual. If it's not anything different, then your fine. It's very, very likely 12VDC.
Old 02-11-2016, 11:35 AM   #9
Rewards Points: 818
Im pretty certain that's what it is. So, is the extra price for an actual sump battery just for the name?
This is what I have: http://www.ebay.com/itm/Basement-Wat...YAAOSwX~dWrXFx
I have a sensor on the watch dog panel that beeps if the fluid gets low in the battery. IF I get a marine grade battery that is sealed, will that sensor just keep beeping? That would be my only concern. I think the sensor pack that plugs into the wall keep everything charged too.
Old 02-11-2016, 12:08 PM   #10
Rewards Points: 459
The fluid sensor is a wire that dips into a cell? Their battery probably just has a hole drilled in the cap. That would not be hard to accomplish. Looks like they're about $129 vs $99 for a standard deep cycle. That's not that far off, so if you're more comfortable with it, go for it.
The Following User Says Thank You to Nick DIY For This Useful Post:
cibula11 (02-11-2016)
Old 02-11-2016, 01:37 PM   #11
Super Moderator
joed's Avatar
If the size fits where it needs, that Exide battery should be fine.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Backup Sump Pump Battery Charger Buzzing ed3120 Plumbing 2 10-28-2013 07:39 PM
Wet Crawlspace has vapor barrier over sump pump. dreiding General DIY Discussions 8 08-11-2013 10:44 AM
Sump pump drain into buried downspouts Chokingdogs Plumbing 1 11-07-2012 11:09 AM
Sump pump back up DennyF Plumbing 4 02-17-2012 01:58 PM
