Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2015, 08:03 AM   #1
Rewards Points: 396
sump pump
Hello,
Can you have a sump pump without weeping tile or do they both have to go hand in hand?
detroittigerfan is offline   Reply With Quote
Old 03-28-2015, 08:16 AM   #2
Civil Engineer
Rewards Points: 5,246
A sump pump is just the pump that moves the groundwater, typically from your basement to away from your house. You also need a sump pit, which is usually a perforated bucket or concrete chamber, to collect the water. You also need a float to control the pump. The weeping tile is the mechanism to collect the groundwater and move it to the sump pit. My house has a thick layer of gravel underneath the basement slab, which allows groundwater to flow to the sump pit, and no weeping tile, so if you have a similar arrangement, you may be able to get away with no tile.
Sump Pump Backup System steve-19 Plumbing 1 01-18-2013 12:15 PM
Sump Pump Backup Delimma steve-19 General DIY Discussions 1 01-16-2013 01:55 PM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
