Sump Pit Filling Faster When Showers Running... - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree8Likes
Old 06-18-2016, 11:21 AM   #31
Rewards Points: 192
Re: Sump pit filling faster when showers running...
No go on the home insurance. I checked, and as usual none of this would be covered.
Operation dig has begun - my hired help flaked out so it's all on me. Luckily this is cathartic work - one shovelfull at a time, I'll get there eventually:
I have a question for anyone that might know. As I'm hacking through hard clay I'm wondering if there's anything else near the sewer that I might harm. Namely, my water supply. Here's a picture of the cleanout and water supply in the basement, can I be reasonably sure the pipe and the supply line are about as far apart from each other as they are here, or would they have been laid in the same ditch together? Any special precautions I should take? Should I maybe call 811 (call before you dig)?
Thanks for the support. Taking a couple hours to eat and cool down and then I'll continue attacking.
MoreCowbell70 is offline   Reply With Quote
Old 06-18-2016, 11:33 AM   #32
Rewards Points: 1,862
If the waterline is in the same ditch it should be 1 foot above the sewer. So be careful once your within a foot of that. If your digging 5 foot down it really is not a hand dig job. See if you can hire an excavator.
Old 06-18-2016, 11:48 AM   #33
Rewards Points: 192
Was quoted $400 to excavate. And wouldn't they need to stop with the machinery at the water line if it's in the same ditch? Happy to do it by hand as long as I don't wreck something. Reassessed the depth, probably just over 4' at the wall. Close to 5' by the cleanout.
Old 06-18-2016, 11:49 AM   #34
Rewards Points: 192
I'm at 2.5ft now. four hours and I'll be there.
123pugsy likes this.
Old 07-02-2016, 11:04 AM   #35
Rewards Points: 248
Well, how did it go? How long did you dig before you hired the excavator?
York v45 is offline   Reply With Quote
Old 07-02-2016, 01:39 PM   #36
Rewards Points: 192
Hah - you guys are funny. It took approximately 5 hours total to get to this:
I put in a few buckets to crusher and tamped down until it felt like a concrete floor - this will never happen again in my lifetime. Called in a plumber, took under and hour to fix everything up nice and tight.
All said & done for under $300. Not horrible.
Thanks for the support!
The Following 2 Users Say Thank You to MoreCowbell70 For This Useful Post:
123pugsy (07-02-2016), Ghostmaker (07-02-2016)
Old 07-02-2016, 01:51 PM   #37
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
That's fantastic. Thanks for the update.
123pugsy is online now   Reply With Quote
Old 07-02-2016, 05:26 PM   #38
Rewards Points: 248
Well done! You're a tougher man than I am. I would have headed straight to the rental yard.
Sump water level pnorman55 Plumbing 18 03-21-2016 12:16 PM
Water running to sump pump bypassing meter givemecoffee Plumbing 20 04-06-2015 05:34 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
Sump filling VERY quickly... Why? leroyme Plumbing 8 08-21-2007 07:30 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 09:36 AM
