Sulfur Smell Coming From Drinking Water Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2016, 11:52 AM   #1
Rewards Points: 99
Sulfur smell coming from drinking water only
I have a drinking water faucet, the line to it bypasses the softener. There are 2 filters in the line. I have a strong sulfur smell that only comes from the drinking water system. I had my non-drinking water tested, and there was nothing abnormal. (I know, I should have had the drinking water tested, long story.)
What I'm wondering is, should I do a chlorine shock treatment on my entire water supply? Or is that overkill? Could there be something else that is causing the smell ONLY in my drinking water?
19mquinn79 is offline   Reply With Quote
Old 10-21-2016, 02:40 PM   #2
Rewards Points: 564
Re: Sulfur smell coming from drinking water only
Hot water heater will cause a sulphur smell also. But only in the hot water, not cold
BayouRunner is offline   Reply With Quote
Old 10-21-2016, 07:39 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 1,734
If the odour contamination is caused by hydrogen sulfide, which is bacterial, a chlorine shock will reduce/eliminate the smell but only temporarily because the contamination is present in the water table. Water softeners can reduce it to below detectable levels but you run the risk of shortening the life of the resin bed.
If it is a result of sulfates, which are naturally occurring mineralization, it won't help.
You should probably have your water tested. You may need a reverse osmosis system.
lenaitch is offline   Reply With Quote
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 06:42 PM
please help fixing the foul water smell dibloff Plumbing 5 06-11-2014 03:42 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
