Suggestions For A Very Stiff Pvc Ball Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2016, 09:07 AM   #1
Rewards Points: 337
Suggestions for a very stiff pvc ball valve
Hello
I have a pvc ball valve on the return side of my irrigation well pump. I don't have to turn it too often, but occasionally I have to in order to use the hose spigot on the pump. Turning it requires 2 hands, and I'm always afraid that the 2 plastic ears will snap off.
I don't really have the option of replacing it since there are other things on that pipe and I don't have room to cut and rejoin pvc.
I've read that I can use soapy water to help lubricate, but I ask if there's something else I can try. I haven't tried the soapy water yet since I read it 5 minutes ago here at work.
Thank you
NABRIL is offline   Reply With Quote
Old 03-15-2016, 09:53 AM   #2
Rewards Points: 6,334
Re: Suggestions for a very stiff pvc ball valve
You'll eventually discover a way to replace it with a good valve when it completely fails so you may as well replace it now and enjoy new valve benefits.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
NABRIL (03-15-2016)
Old 03-15-2016, 12:56 PM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Originally Posted by NABRIL View Post
Hello
Thank you
take the handle off and spray with some silicone lube, then put handle back on and see if it helps, if not replace..
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
NABRIL (03-15-2016)
Old 03-15-2016, 12:59 PM   #4
Rewards Points: 337
Thank you..How do you remove the handle? It's connected to the rotating ball, no?
Old 03-15-2016, 01:03 PM   #5
should have a screw on top, if not try squirting the spray and twist the handle as your doing it to try and work the lube down onto the ball of the valve..
Old 03-15-2016, 01:12 PM   #6
Oso954's Avatar
Rewards Points: 1,840
PVC ball valves are notorious for sticking, especially when they are not used regularly. One of the best things you can do is to exercise them regularly. If you get near it, open and close it or vis versa.
I've gotten to the point where I do not use them anymore unless it is a cheap and temporary thing. For anything permanent, I get the brass ball valves.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
NABRIL (03-15-2016)
PVC Ball Valve Manifold 7SistersRanchTX Plumbing 3 03-27-2013 12:19 AM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Leaking ball valve in a gas line jshansen32 Plumbing 17 07-13-2012 09:58 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
