Sudden Water Stoppage - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2016, 07:41 PM   #1
bgbrown125's Avatar
Rewards Points: 63
Question
Sudden water stoppage
We're running bath water for grand and the hot and cold water stopped. I turned on the vanity faucet and minimal water flow. We have a deep well here in the NC mountains, submersible pump over 350' and a bladder tank under the house.
I accessed the contacts at the tank and tapped on the cover. I returned inside and we had water again.
What should I do at this point.
Thanks in advance
Barry
bgbrown125 is offline   Reply With Quote
Old 11-05-2016, 09:20 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,468
Re: Sudden water stoppage
Clean the contacts and hope that it isn't the pump going out intermittently and getting ready to fail.
Check all the connections and rule out any electrical gremlins.
Tags
contacts , water
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
