Subslab Radon Suction With High Water Table - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2015, 07:59 PM   #1
Rewards Points: 388
Question
Subslab Radon Suction with High Water Table
When I dig into the slab is water going to come up?
enochian is offline   Reply With Quote
Old 12-29-2015, 03:24 AM   #2
Rewards Points: 2,030
If you feel you are going to have that high of a water table, you should start with a sump pit or two. Sump pits can be incorporated into a radon system and ensure the water level stays below the slab. Currently, I doubt the water level is right below the slab as you would be having extreme moisture problems. When was the house built?
Bud
Bud9051 is offline   Reply With Quote
Old 12-29-2015, 10:40 AM   #3
Rewards Points: 388
House was built in 2014.
Already have 2 sump pits, 4 sump pumps and Generac.
Old 12-29-2015, 10:57 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,.... Then the water level under the slab should be no higher than the water ya see in the sump pits,....
Why are ya gonna pound another hole in the slab, when ya already got 2,..??
Old 12-29-2015, 02:52 PM   #5
Rewards Points: 388
Because I need to have access to the sump pumps.
Old 12-29-2015, 04:53 PM   #6
The details I have read about show the sump pits covered and sealed so the radon fan can pull a negative pressure below the slab. If the pit and system are installed at the same time they have lids specifically for that.
Was the plumbing for your radon system installed when the house was built?
Bud
Old 12-29-2015, 05:00 PM   #7
Rewards Points: 388
My sump pits have channels that goes to the perimeter channel.
So you wouldn't be able to get a seal anyway.
Haven't checked in the attic yet. I don't want to pump radon internally through the house anyway.
Old 12-29-2015, 05:59 PM   #8
It is the plumbing below the slab that needs to be in place. If the below slab space is not sealed from the basement you will just be pumping basement air out of the house. A radon system establishes a negative pressure below the slab, including the perimeter drains and captures the gasses before they can enter the living space.
Lots of information in the internet.
Bud
Old 12-29-2015, 07:26 PM   #9
Rewards Points: 388
Then my Googling must be weak.
Please link to info.
Old 12-29-2015, 09:31 PM   #10
We must be thinking two different things. Radon mitigation is most often a sub-slab suction system and can be connected through a sump pit.
"One variation of subslab and drain tile suction is sump hole suction. Often, when a house with a basement has a sump pump to remove unwanted water, the sump can be capped so that it can continue to drain water and serve as the location for a radon suction pipe." From http://www.radon.com/pubs/consguid.html
That's just one, search "radon system design" for many more.
Bud
Old 12-29-2015, 09:41 PM   #11
Rewards Points: 388
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
