Subermersible Utility Pump Not Pumping - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By supers05
Old 10-21-2016, 11:24 PM   #1
Rewards Points: 2
Subermersible utility pump not pumping
We have a Pacific Hydrostar Utility Pump and for the first week of using it, it was fine. Now it's not quite working properly. Without a hose attached it pumps perfectly. But as soon as we attach any hose to it, no water pumps through. It sounds like it's pumping, just nothing comes out.
Any help would be much appreciated.
Sent from my Nexus 7 using Tapatalk
Code101 is offline   Reply With Quote
Old 10-21-2016, 11:37 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Subermersible utility pump not pumping
Sounds like a seal or the impeller needs replacing.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-21-2016, 11:55 PM   #3
Rewards Points: 2
Thanks for the reply. Would these cause it to only pump with no hose attached?
Old 10-22-2016, 01:36 AM   #4
Rewards Points: 80
Something stuck in the intake opening?
Cheers!
joecaption likes this.
supers05 is offline   Reply With Quote
Old 10-22-2016, 10:41 AM   #5
Rewards Points: 2
I checked the impeller and inside and everything is fine. No blockages at all. Without a hose it pumps water through fine. Just when I attach a hose to it no water comes through the hose. I tried putting the hose on an outdoor spigot and it has no blockage in the actual hose. Could it be an airlock in the hose or somewhere in the pump? The model we have doesnt have a check valve so I can't examine that. It's really a frustrating problem. Thanks for all the replies.
Sent from my SM-N920P using Tapatalk
Old 10-24-2016, 12:34 AM   #6
Rewards Points: 80
What's the lift that you're trying to get out of this pump? Have you tried just a short piece of hose? No lift, say out of a bucket?
Impellor style pumps lose their lift capacity when their clearance to the housing is too large. (from the intake opening to the impellor) sounds like something came loose.
If it's the same pump as below, 23' is the max height. It's unlikely that you'll even have half of that. Including the resistance of the hose. An air bubble in the hose won't cause a problem. The design of the pump will keep bubbles out of the impellor.
http://m.harborfreight.com/16-hp-sub...not%20provided
Cheers!
Sump Pump Running Constantly - Never Ending Water! seldom Plumbing 7 12-08-2015 07:59 AM
Venting utility sink pump dbooksta Plumbing 1 06-13-2013 07:31 PM
Septic pump will not turn on by itself ukrkoz Plumbing 2 04-23-2013 10:38 AM
MasterCraft shallow well pump not happy rtoni Plumbing 7 06-06-2011 11:41 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
