Stud Show Sizing - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By bob22
Old 04-25-2017, 06:59 PM   #1
Rewards Points: 28
Question
Stud Show Sizing
Soooo did the holes for the 1 1/2 pipe for a drain, double studs. Ordered the Stud Shoes from home Depot and bammmm they dont fit. The original wood in the house 1945 is just a tad wider than current studs.
Suggestions?
jpisme is offline   Reply With Quote
Old 04-26-2017, 08:49 AM   #2
Rewards Points: 2,650
Re: Stud Show Sizing
I'll bite; what are Stud Shoes? Don't tell me "anything my wife says are on my feet" either!
MTN REMODEL LLC and lenaitch like this.
bob22 is offline   Reply With Quote
Old 04-26-2017, 09:04 AM   #3
Rewards Points: 18,990
Before the pipe went in you could have used a jigsaw, plane, occilating saw, even plunge cutting with a circular and finishishing it out with a wood chisel to narrow it up the needed amount.
Here's a picture of a stud shoe.
http://www.mudsupply.com/Simpson-Str...AKcaAkjC8P8HAQ
Old 04-26-2017, 09:24 AM   #4
Rewards Points: 28
It is what I get for typing so late. it was supposed to be shoe.
Old 04-26-2017, 09:26 AM   #5
Rewards Points: 28
I have not put the pipe through yet so if it is acceptable to put the stud on a diet to get the shoe to fit then that can be done.
The Following User Says Thank You to jpisme For This Useful Post:
bob22 (04-26-2017)
Old 04-26-2017, 09:29 AM   #6
Take a small amount off each side.
All your doing is reducing it to the size of a modern stud.
Old 04-26-2017, 08:53 PM   #7
Rewards Points: 1,952
The wood use to actually be a 2 inch by 4 inch cut.
The only time you need stud shoes is if it is a bearing wall. Other wise nail plates will do.
The Following User Says Thank You to Ghostmaker For This Useful Post:
bob22 (04-27-2017)
interior wall frame has an angled piece at bottom of one stud. Why! waitingtohear Building & Construction 14 05-03-2012 08:50 PM
Moving a socket from left and stud to right hand stud(and up 3 feet) raptor_demon Electrical 19 04-03-2012 10:27 AM
How many holes can I drill into a wood stud? lostintyme Building & Construction 8 02-28-2012 07:26 PM
When to replace rotted stud vs. epoxy ken57 Building & Construction 4 11-08-2011 06:48 AM
Is it safe to remove this stud? lofar Remodeling 4 06-16-2009 11:22 PM
