Stuck Threaded Diverter Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2016, 02:03 PM   #1
Rewards Points: 2
Question
Stuck threaded diverter tub spout
I have a diverter tub spout that failed and I tried to twist if off but it wonít budge. I know it is a threaded spout because I canít find a setscrew anywhere on the on the outside. The diverter pull is positioned towards the back instead of the front. Everything Iíve researched shows that removing it should be as simple as turning it counter clockwise but I cannot get it to budge. How the heck do I get it off without damaging the pipes?
cduran415 is offline   Reply With Quote
Old 11-08-2016, 04:28 PM   #2
Rewards Points: 18,772
Re: Stuck threaded diverter tub spout
Look on the bottom side of the spout near the wall, is there a 1/2 of an oval shaped hole?
If not there is no screw.
What are you using to try and remove it?
Tags
diverter tub spout , stuck
Tub spout diverter operation question daluu Plumbing 7 02-06-2013 07:16 PM
where do I set the black o- ring on the tub spout? or the threaded copper pipe? radioflyer77 Plumbing 1 07-05-2012 09:23 PM
Stuck Gerber Tub Spout - How to remove? edwardk77 Plumbing 5 05-17-2012 11:01 AM
Switch shower diverter from fixture to spout? iruser Plumbing 0 06-21-2010 10:52 AM
Bathroom Tub Diverter Spout karenmc Plumbing 3 07-24-2009 03:23 PM
