Stub-out Length - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2018, 09:09 AM   #1
Rewards Points: 193
Stub-out length
Hi all,
The plumber left four or so inches of 1/2" capped copper pipe extending from the finished wall to supply the toilet and vanity hot/cold water. Question - I need cut the copper pipe and install the compression fit water valves, how much should I leave extending from the wall? Thanks
Jack E is offline   Reply With Quote
Old 10-22-2018, 09:32 AM   #2
Rewards Points: 1,980
Re: Stub-out length
Will you be using chrome covers to dress it up?
Cut pipes as close to the wall as you need to accommodate your compression fit water supply shut-off valves. For sink; remember the drain p-trap. Just a suggestion and my own opinion, others may disagree.
jmon is offline   Reply With Quote
Old 10-22-2018, 08:52 PM   #3
Rewards Points: 193
Re: Stub-out length
Yes, I'll be installing chrome covers. I'm wondering if there is a standard length to leave stubbed-out taking in to account the cover - 1"? Maybe it will become apparent after I pick-up the valves and see how they attach to the copper pipe.
1/2" NPT brass nipple with 3 1/4" length needed. noone Plumbing 10 08-09-2013 05:49 AM
Should I splice to shorten length? Troy32 Electrical 11 12-08-2012 08:13 PM
Maximum hardwood flooring length EE_Steve Flooring 3 10-20-2012 10:51 PM
LED strip length? Karpiel73 Electrical 4 04-29-2012 09:46 PM
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 08:10 AM
