Steel/Porcelain Tub Filler - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2014, 06:19 PM   #1
From Philadelphia
Rewards Points: 291
I was installing wall tile in a shower and dropped one in my new bathtub. It's a standard inexpensive porcelain-coated steel tub for $129. It left a pretty deep dent/gash in the tub, and the manufacturer's touch-up paint alone won't cover it up. It's a perfect color match, but it won't fill in the gouge; you can still see the gouge in the tub.
So, do you have any recommendations for something a little thicker I can use to fill in a big gouge/dent like that? Then I will apply my touch-up paint on top of it. Any recommendations are appreciated. Thanks!
hellohello is offline   Reply With Quote
Old 12-30-2014, 06:41 PM   #2
Rewards Points: 3,430
I have seen different tub repair kits at the hardware/big box stores. Never used them before so really can't say if they work or not. Just a thought.
jmon is online now   Reply With Quote
Old 12-30-2014, 08:21 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,234
Ayuh,.... Is it a Dent, or a Gouge,..?? Big difference,...
Ya might be able to fair it flat with an epoxy putty, 'n then paint it with the stuff ya got,....
Ya gotta start by sandin' it, so's the epoxy will stick,... Go fairly coarse paper,...
Fair it out,...
Resand, with fine paper, 'n then try yer paint,....
If a dent, it might hold,...
If a gouge, it'll stand a better chance of lockin' the epoxy in,...
Bondo is online now   Reply With Quote
Old 12-31-2014, 05:54 PM   #4
Rewards Points: 1,932
Let me ask, If you can replace the tub I would. If you cant then hire a professional porcelain tub re finisher.
help cutting cabinet filler boards mycorrado Kitchen & Bath Remodeling 7 10-06-2014 05:22 AM
Which filler should I use for exterior? Homerepairguy Painting 23 08-24-2014 03:36 PM
Roman Tub Filler BatocheBob Plumbing 2 04-28-2014 07:39 PM
Help with adding custom color to wood filler 4thDimension Carpentry 5 10-14-2011 01:46 PM
do not use concrete filler to fill stones... KUIPORNG Landscaping & Lawn Care 4 08-29-2008 04:16 PM
