Standing Water Garbage Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree17Likes
Old 08-02-2017, 05:28 PM   #16
Tizzer's Avatar
Rewards Points: 148
Re: Standing water garbage disposal
Originally Posted by Justin10k View Post
My only option now is the landlord. Unfortunately I'm not the only one who "lives" here my older brother pays half rent while my parents pay the other half. My brother now stays at his girlfriend's house leaving me all his messes to clean up and problems to solve. I've tried getting him to call the landlord to fix our disposal, but it just ended in big fight. I don't have the lease or information that has the landlord or management's office's phone number.
I have a feeling the garbage disposal was wrecked before I moved in because the first time I tried using it I could hear things bouncing around inside there. My brother said he used the sink to dump old water from his fish tank so I'm guessing he got fish tank pebbles down the garbage disposal. The only thing I ever put down there was washing my grease trey from my T-fal grill I was using at the time.
Sorry Justin, but your only option now is not calling the Office. You are not on the lease. Your parents/brother or whomever is on the lease can call.
Can you shine a flashlight down and see anything inside?
People here will probably boo me for this, but I've stuck a hand down and felt for stuff jammed down there. And yes, I'm aware I could loose a finger if the switch got turned on.
Are you in a position to take over the Lease from your brother?
JERRYMAC and Nik333 like this.
Tizzer is offline   Reply With Quote
Old 08-03-2017, 05:05 AM   #17
Naildriver
chandler48's Avatar
Rewards Points: 3,528
Better than your hand, use a shop vac to suck everything out so you can see what is happening. Still, it is a rental. It is not a good idea to be messing with someone else's property.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 08-04-2017, 07:00 AM   #18
Rewards Points: 18
Thank you all for taking the time to read and post. I tried one last ditch effort in putting a hex wrench into the bottom of the disposal and turn it manually, but it didn't seem to do much. I got a little excited when I saw a few bubbles come up from the disposal, but alas the sink still has standing water.
For instance in his smoking area by our sliding door he had several mountain dew cans sitting there where he was using them for ashtrays. There had to be over 200 cigarette butts either in the cans, on them, or just laying on the counter. They sat their so long the filters in the cigarettes grew so hard when I tried to vaccum them up with the hose the butts clogged the hose forcing me to pick them all up instead.
I would suggest trying the hex wrench again, but this time, rotate it in both directions. With the hex wrench, you are trying to dislodge whatever is wedged between the blades and the frame of the disposer. If you turn the wrench in both directions it oftentimes will dislodge whatever is wedged. If that is successful, turn off the circuit breaker and the switch, and use a pair of tongs or even your hand (before I get yelled at, I know that could be dangerous) or a shop vac to try and remove the debris. One caveat... If there is liwuid plumber in the disposer you MUST wear an acid proof rubber glove.
Good luck!
Sent from my LG-D415 using Tapatalk
JERRYMAC likes this.
jeffmattero76 is offline   Reply With Quote
Tags
garbage_disposal , kitchen_sink , standing_water
Garbage disposal outlet installation RonnieJ Electrical 20 03-05-2017 09:45 AM
Double sink w/ Garbage Disposal ,shoots up the other learningToDIY Plumbing 10 01-04-2016 06:48 PM
Dishwasher drainage mystery instrumentally Plumbing 13 06-16-2015 02:21 PM
Standing water in my backyard!! sam2015 Landscaping & Lawn Care 2 04-30-2015 12:17 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
