Squeaking Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2016, 07:29 AM   #1
Rewards Points: 44
Squeaking Tub
Hello all, I have a shower/tub that's been squeaking since we bought the house, it's highly irritating and I'm sure not good for the fiberglass tub - probably eventually something will crack.
From what I can see from below (just removed ceiling from 1st floor) is a 1 foot hole for the plumbing and it appears the tub is largely unsupported underneath - from the view I have, I can *see* nothing supporting it.
I watched the video a couple weeks ago where this gentleman installed a tub with expanding foam as a support method:
I'm wondering folks if I could so something similar from underneath? The majority of the squeaking is from the low end of the tub, where I have some limited access. Removing the tub is not an option.
TIA,
-Jason
maj28 is offline   Reply With Quote
Old 06-14-2016, 07:50 AM   #2
Rewards Points: 18
Re: Squeaking Tub
I bave heard of guys using spray foam, but i prefer either mortar or structolite ( a kind of plaster). Problem is that those are usually installed before the tub and the tub squashes down into the wet mortar or structolite. I guess you could try shims under the tub and thwn trying to force mortar under the tub and then remove the shims but i think you would have very limited success.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 06-14-2016, 12:14 PM   #3
SHEPLMBR's Avatar
Rewards Points: 178
Re: Squeaking Tub
use a combination of both. first mortar then fill gaps with spray foam.
SHEPLMBR is offline   Reply With Quote
American Blower attic fan squeaking after belt change Deck HVAC 5 07-03-2014 03:31 PM
What could be the cause of a squeaking noise in my bathtub? aadambass Kitchen & Bath Remodeling 3 07-21-2013 10:48 PM
trying to fix squeaking stairs... liverlipsyyz Building & Construction 13 10-12-2012 06:51 PM
squeaking hardieboard floor jbitt Flooring 2 06-03-2010 08:25 PM
Squeaking Oven Hobb3s Appliances 5 05-08-2008 01:03 PM
