Sprinkler PVC Cracked Near Prevous Repair Coupling - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2015, 05:45 PM   #1
Rewards Points: 24
Sprinkler PVC cracked near prevous repair coupling
We have a leak spraying out right next to an existing repair coupling (see pic). Presumably, we are going to have to completely cut out the old repair coupling to fix this. However, this is going to leave a much larger gap than can be bridged by a standard coupling.
Is there a special piece we need to bridge this larger gap?
Any advice you can lend that will help with this repair will be greatly appreciated!
S_Jeff is offline   Reply With Quote
Old 11-12-2015, 05:53 PM   #2
Rewards Points: 262
If you have some flex in the pipe, two regular couplings and a piece of pipe will get you going. If there's no flex, look for slip-couplings. They are couplings without a stop inside. You put the couplings over the pipe then slide them over the joint.
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Colbyt (11-12-2015)
Old 11-12-2015, 07:52 PM   #3
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
Look for an expandable repair coupling. Make sure everything is clean and dry, use PVC primer, and let the glue cure for a while before you turn it back on.
I hate signatures.
Mort is offline   Reply With Quote
Old 11-13-2015, 08:49 AM   #4
Rewards Points: 767
I'm saying that is the original break that pulled itself out of the coupling because it was pressurized before glue set. Look at the blue rain/shine glue ring around that split
ct18 is offline   Reply With Quote
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Repair cracked "plastic" bumper cover? (Ford escape) rossl56 Automotive Repairs 6 08-27-2009 08:03 AM
Cracked dashboard repair... trentv123 Automotive Repairs 1 08-05-2008 09:28 AM
How to repair cracked concrete stair? curls00 General DIY Discussions 1 03-17-2008 12:57 PM
Repair cracked glass cooking hob Anto318 General DIY Discussions 2 01-03-2008 12:24 PM
