Spoiled Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2017, 06:10 AM   #1
Rewards Points: 18
Spoiled Drain?
Good day! I had a plumber come in to work on my shower drain and he told me the drain was "spoiled" ie had remnants of toilet flushings in it
Upstairs washroom with a shower, toilet, sink and washer. No other floors above this (other than attic). Part of an addition put on approx. 5 years ago so new plumbing was tied into old.
I'm 95% certain a new vent was installed but somewhere in the past the venting was called into question by other tradesmen and I can't recollect why.
A quick Google search didn't bring up anything and I can't quite figure out how it is possible and what a fix might be.
tjroland is offline   Reply With Quote
Old 03-30-2017, 08:59 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,672
Re: Spoiled Drain?
What is the slope on the drain pipe and you need to confirm the venting. No reason it should fail to drain like that.
If it isn't vented, it will not drain properly so you need to confirm that. Did the plumber not verify this? It shouldn't be difficult.
Old 03-30-2017, 01:45 PM   #3
Rewards Points: 1,952
Re: Spoiled Drain?
No inspection?
Old 04-02-2017, 10:47 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Re: Spoiled Drain?
What was he doing with the shower Drain in other word what did you call him out for. spoils from sewage are not uncommon in a shower when you have a back up in the branch.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Connecting Wet Bar Vent and Drain LowlyDIYer Plumbing 1 09-12-2014 04:41 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
