Soldering Plumbing Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2016, 01:16 PM   #1
Rewards Points: 1,206
Soldering plumbing copper pipe
Have a copper pipe in my boiler room that has a leak at the soldered joint. It's a drip like every minute. I bought a propane tanks, flux, solder and grit cloth.
Any advice on how to do this? Assuming should sit my gas off so I'm safe in the room.
Mstrlucky74 is online now   Reply With Quote
Old 01-24-2016, 01:21 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
you will need to shut off the water and drain the pipe, no need to shut of gas to the boiler or water heater..best bet is to heat up and take the joint apart , clean with a fitting brush of any corrosion, sand the pipe with grit cloth of any corrosion , flux up the parts and put back together and heat the joint with the torch, heat from the opposite side you are feeding the solder in so you know the pipe and fitting are hot enough and the solder will flow to the heat, let cool, wipe off any extra flux and test..
WhatRnsdownhill is offline   Reply With Quote
Old 01-24-2016, 01:40 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,312
and drain the pipe,
Ayuh, 'n that's the Key,....
The pipe/ joint area has to be completely Dry, both inside, 'n out,....
Old 01-24-2016, 02:20 PM   #4
An old Tradesmen
Rewards Points: 9,504
Post pics of pipe and where it goes to. Small/slow leaks are sometimes best left until spring to repair.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (01-24-2016)
1/2 copper pipe soldering Kenf Plumbing 6 10-14-2014 11:17 PM
Soldering a leaky pipe WyrTwister Plumbing 14 02-15-2014 05:57 PM
Mysterious Problem with Copper Drain Pipe "Growing" into the Shower imautoparts Plumbing 3 10-16-2012 02:27 PM
Copper Pipe vs Copper Coil Tubing For Refrigerator Water Line kaalapurushha Plumbing 3 10-15-2012 08:59 PM
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-13-2011 11:48 PM
