Soldering Directly To T/S Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By LeakyMike
  • 1 Post By carpdad
Old 10-28-2016, 12:22 PM   #1
Rewards Points: 252
Question
Soldering directly to T/S Valve?
We are adding a new bathroom and the first part of the plumbing has just been installed.
Most looks OK, but one connection troubles me. See attached picture.
I'm concerned that heat from soldering the copper pipe directly to the Delta MultiChoiceT/S Valve Body might have damaged the valve.
I can get another valve and ask the plumbers to attach it "correctly" if that seems advisable.
Soldering directly to T/S Valve?-img_6459.jpg
John_W is offline   Reply With Quote
Old 10-28-2016, 01:41 PM   #2
Rewards Points: 252
Re: Soldering directly to T/S Valve?
I just saw a video that showed the inside of this valve body. The whole thing is brass so there is nothing to melt.
Old 10-28-2016, 06:36 PM   #3
Rewards Points: 55
Always a good practice to test your shower/tub facet combination before you
enclose the space with rock or what ever your using for the wall. Also , in my opinion, given modern brass fixtures and valves are lead free mostly, I pull the guts from them when I can before applying heat to get lead free solder to flow. Soldering is an all new skill set now days.
John_W likes this.
LeakyMike is offline   Reply With Quote
The Following User Says Thank You to LeakyMike For This Useful Post:
John_W (10-29-2016)
Old 10-29-2016, 10:13 AM   #4
Rewards Points: 1,250
Second on testing before closing it. As a diy, I always use the screw on adapters with a short length of tail, keep the valve open and cool it down quickly with water or wet rag.
John_W likes this.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
John_W (10-29-2016)
Old 10-29-2016, 01:26 PM   #5
Rewards Points: 252
I'm sure the plumber soldered that connection before installing the valve.
Lead free soldering sounds challenging. I've only soldered with 50/50 tin/lead solder - and only electronic parts.
Old 10-30-2016, 09:18 PM   #6
Rewards Points: 55
Yeah and my thing with lead free brass is the heat you need to get the 95/5
to flow into it. I've found Oatley 95 tinning flux to be a great help with that.
I do not like the water based eco friendly (so called) fluxes. Map gas or my
b tank acetylene torch work well for this. The days of 50/50, 60/40 and propane
for potable water are long over. Little bit of a learning curve but a patient man
can do it.
Aprilaire 400M Humidifier, cannot open saddle valve! mtlmonk HVAC 1 12-14-2013 05:56 AM
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 12:29 AM
Mixer valve to transfer valve installation CarlV Plumbing 0 09-13-2011 11:28 AM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
