Softener Resin? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2016, 03:47 PM   #1
Rewards Points: 8
softener resin?
I just bought a Morton M34 Water Softener. When running bath water, a light brown/yellowish sand type substance is piling up near the drain. When I bypass the water softener, this does not happen. The people at Morton told me to return it because the distributor was ruptured. So I did, which was extremely difficult. I exchanged it and installed a new one. The substance is still there! Could I really have gotten 2 defective water softeners?
i wanted to post a picture, but it won't let me
scubaslim is offline   Reply With Quote
Old 05-20-2016, 04:23 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,668
Re: softener resin?
That definitely sounds like resin.
It could be that the resin has piled up in the hot water tank and needs to be flushed out. Try running just the cold and see if you get it.
Old 05-20-2016, 04:26 PM   #3
Rewards Points: 8
Re: softener resin?
yeah, it happens with the cold too.
Old 05-20-2016, 04:26 PM   #4
Rewards Points: 8
Re: softener resin?
http://www.plumbingforums.com/forum/...3&d=1463776273
here's a picture
Old 05-20-2016, 05:25 PM   #5
Super Moderator
joed's Avatar
Re: softener resin?
Looks like resin.
I suppose if there was a manufacturing flaw it could be in more than one unit.
What is the water pressure in your house? If it is too high maybe that is contributing to the issue.
Old 05-20-2016, 05:38 PM   #6
Rewards Points: 8
Re: softener resin?
Looks like resin.
I'm not sure -- its seems normal. How do I test the water pressure?
Old 05-20-2016, 07:15 PM   #7
Rewards Points: 8
Crap, I'm a huge idiot! It's hooked up backwards.... is the softener screwed up permanently now?
Old 05-20-2016, 10:11 PM   #8
Super Moderator
joed's Avatar
Re: softener resin?
Depends how much of the resin got pumped out.
water softener leaking only in winter Photogd Plumbing 6 11-14-2015 05:31 AM
Incomplete softener flushing dadaddio Plumbing 59 01-02-2014 06:03 PM
Pan under water heater is corroding? neight Plumbing 39 06-05-2012 10:22 AM
Water Softener Resin Bed Clogging with Sediment? batman71 Plumbing 2 02-23-2011 11:38 AM
Water Softener Resin kb3ca Plumbing 5 10-20-2010 01:56 PM
