So The Builder Did This... - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2016, 05:28 PM   #1
Rewards Points: 8
So the builder did this...
Hello,
Doing a minor renovation on a bathroom in SC (vanity, paint, floor), and I find this when I pull the vanity out. The builder ran the cold water tap going over to the toilet in front of the vent riser preventing the drywall from sitting flush (they conveniently just knocked a hole in the drywall prior to installing the original vanity). The water line is CPVC coming up from the slab. To fix the drywall issue I want to cut the CPVC directly below the 1st tee, install a new coupling with a short piece of CPVC going to a new tee and run PEX out of the top of the tee over to the toilet using a CPVC to PEX adapter at both connections (There is more room toward the top of the riser allowing room for both PEX and drywall). Anyone see an issue with this plan? How would you do it?
Appreciate the help.
So the builder did this...-img_0389.jpg   So the builder did this...-img_0390.jpg
ScooterBiggs is offline   Reply With Quote
Old 03-27-2016, 06:11 PM   #2
Property Mgt/Maint
Rewards Points: 8,186
Re: So the builder did this...
The builder didn't do this. Some hack afterword did this. If you run a pipe thru a stud that close to the edge use nail guard plate. Being such a shallow cavity, if possible you might want to just run the pex straight up and then over if access will allow it. Pex tubing is inexpensive
Yodaman is online now   Reply With Quote
Old 03-27-2016, 06:25 PM   #3
Rewards Points: 8
I purchased the house new, so apparently they did it. Not sure how it passed inspection, but it is what it is. There is a nail guard in front of the hole, it's just difficult to see in the picture. I plan on looping the PEX over to the toilet supply. Appreciate your input.
Argument with new home builder - Flat roof ponding avonord General DIY Discussions 55 07-29-2015 06:12 PM
Deck built by builder: mains supports for the hand rail going around deck is pickets? mrrich01 Building & Construction 10 10-04-2012 10:06 AM
home builder dissolved-roofing co refuses responsibility for roof- Help cp31817 Roofing/Siding 7 05-03-2012 01:01 PM
Tips on selecting a home builder nordic587 General DIY Discussions 11 02-06-2012 12:45 PM
Profit margin "to give" to builder in CT darens67 Building & Construction 3 04-21-2011 05:34 PM
