Smelly Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-29-2016, 10:13 PM   #1
Rewards Points: 27
Smelly water
My hot water smells like sulfur (rotten eggs). Does anyone know how to fix this or what causes it? Ive tried running the hot water to try anf drain the water heater but doesn't seem to help. I live in a townhouse neighborhood in Houston texas if that helps
Cold water works fine, just the hot water smells
woodenSpoon is offline   Reply With Quote
Old 04-29-2016, 10:53 PM   #2
Rewards Points: 127
Turn the temp up on your water heater . I found by increasing the temp on my well supplied water heater from 120 to 130 killed the sulfurous bacteria .
jimn01 is offline   Reply With Quote
Old 04-30-2016, 09:15 AM   #3
Rewards Points: 18,772
Re: Smelly water
Most often changing the anode rod to a magnesium rod will take care of it.
May need an impact wrench to remove it.
https://www.google.com/search?q=wate...S-4gJqswZFM%3A
Salty, smelly well water sonofbuster Plumbing 8 03-24-2015 12:58 AM
Sink arbitrarily fills with smelly water. beatmixer16 Plumbing 10 01-20-2015 09:17 AM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
