Smell From Washing Machine Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2016, 07:50 AM   #1
Rewards Points: 64
Smell from Washing Machine Drain Pipe
Hi all,
I recently switched out my conventional top-loading washing machine for a front-loading HE model, and pretty quickly after installing it, noticed a smell coming from the washing room. As best as I can figure it out, it seems to be coming from the drain pipe for the wastewater that is up in the drain box in the wall.
I checked and the drain hose is not too far down and past the P-trap, it only goes a few inches in.
One noticeable difference is that the previous drain hose completely filled up the hole, whereas the new drain hose is much smaller.
Another thing I have noticed is that after I ran the self-clean cycle (several hours long, using hot water) the smell seemed to go away for a few days.
Any ideas out there?
Thanks!
shan1289 is offline   Reply With Quote
Old 10-09-2016, 08:04 AM   #2
Rewards Points: 3,294
Re: Smell from Washing Machine Drain Pipe
We cannot rule out lint or other residues within the drain pipe or even within the drain hose rotting and giving off odors.
With the drain hose filling up the hole less odor will get out, but the hose is supposed to fit loosely.
A clogged vent further on in the drain pipe system could result in siphoning out of the P trap for the washing machine drain and letting odors come up that way.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 10-09-2016, 09:29 AM   #3
Rewards Points: 1,866
Clean the seal around your front loader door. These type of washer are notorious for stinking. I think there is a class action lawsuit in process.
Old 10-09-2016, 09:37 AM   #4
Rewards Points: 18,808
Is there a trap in the drain line?
Is the drain line 2"?
Old 10-09-2016, 05:53 PM   #5
Rewards Points: 450
Are you leaving the door open when not in use? The door needs to be left open, this is usually in the manual....at least every manual I have read for front loaders. Front loaders seal tight so the residual water can't evaporate, so basically it becomes stagnant which starts to smell. On top loaders the lid doesn't seal tight so it can naturally ventilate and evaporate.
KC_Jones is offline   Reply With Quote
Old 10-09-2016, 06:03 PM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,766
As Ghost says.... YES, there were material lawsuits and claims... google it and there are rather lengthy explanations.
If I recall correctly, I think the problem was predominate in pre 2010-11, and I think newer models have better cleaning/ drainage systems... but doors are still supposed to left open and system cleaned intermittantly.
Is your frontloader new or an older model.?
MTN REMODEL LLC is offline   Reply With Quote
Old 10-09-2016, 06:04 PM   #7
Rewards Points: 38
That would explain the smell. Seems OP is missing a required P-trap on the drain line. Old washer did not smell because pipe was completely capped by old drain hose. Check for the P-trap.
SHR Plumber is offline   Reply With Quote
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
Correcting washing machine drain KansasCity Plumbing 8 07-07-2013 08:57 PM
Help! Need advice about washing machine drain! tippinon44s Plumbing 3 09-22-2012 12:44 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
