Small Gouge In Abs Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2016, 09:37 PM   #1
Rewards Points: 2
Small gouge in abs pipe
I recently installed an abs p-trap for my shower drain and made a small gouge on the inside of the p-trap with the pry bar I was using to keep it propped up while attaching the lower drain flange. I can provide a picture, but the gouge is about 1/8" long and 1/16" deep. It lies in the zone where water will sit in the p-trap. It does not appear as though water is leaking as I have filled the drain multiple times and the water level in the p-trap does not change over time. Is there reason for concern? Does the inner core of abs pipe breakdown over time in response to shampoos and soap and thereby a leak developing in the future? Any advice would be appreciated! Thanks!!
Cstoehr1 is offline   Reply With Quote
Old 01-25-2016, 05:54 AM   #2
Rewards Points: 18,762
Not going to be an issue.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
dd57chevy (01-25-2016), oh'mike (01-25-2016)
How to create a computer desk design to fit small home office spaces PD_Lape How To Guides 12 04-01-2015 04:34 AM
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
