SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 05-28-2016, 02:05 PM   #16
Rewards Points: 1,852
Re: SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve?
The plastic faucet is probably split by the old all metal lav supplies you have on it. Replace it.
Old 05-28-2016, 02:17 PM   #17
Rewards Points: 229
And you don't think putting new caulk around faucet base will resolve the issue??
Where in the faucet is it leaking then?
Sean Price is offline   Reply With Quote
Old 05-28-2016, 02:19 PM   #18
Rewards Points: 229
Whoops just saw the additional replies..
Replace it is..
Thank you good sirs!!
Sean P
The Following User Says Thank You to Sean Price For This Useful Post:
jmon (05-28-2016)
Old 05-31-2016, 11:51 AM   #19
Rewards Points: 229
all right gents, I am GAME!!
lets do this..
I want to do it right and TIMELY.. so need your help putting it all together, i.e. replacing faucet, and adding shut off valves..
1. Faucet $10 at HomeDepot
2. SS Flex line? So basically any steel braided line right, appropriate size fittings and lenth, $5-10?
3. Since pipe coming from wall I need two 90 degree 1/4 turn stop valves correct? Any suggestions or input for Menards/HomeDepot?
4. What else would I need, plumbers putty, do I need to seal the faucet to the sink top in any way?
any and all suggestions greatly appreciated!
regards!
Sean P
Old 05-31-2016, 12:29 PM   #20
ZTMAN's Avatar
Rewards Points: 604
If this is a daily use bathroom, pick a different faucet. A $10 faucet is no bueno. I didn't see a pop up drain control on the one in your link either
ZTMAN is offline   Reply With Quote
Old 05-31-2016, 12:39 PM   #21
Rewards Points: 229
not trying to be hard case here, but what good is a pop up drain?
In the 5 years i've owne this house I've not used it once on this daily use sink.. but again if I need it, i'll buy it..
That same model sink WITH the pop up drain is $20.. please advise
Sean P
Old 05-31-2016, 01:07 PM   #22
ZTMAN's Avatar
Rewards Points: 604
It looks like the one you are replacing has the pop up drain handle as part of the fixture. If you dont buy one to operate the pop up, it will stay in the down position
Old 05-31-2016, 05:02 PM   #23
If you spend a little now on a moen or delta. It will be the last money spent.
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
Bathroom sink drains slow, opening and closing stopper will get it to drain fast Arsinek Plumbing 5 05-11-2014 12:30 AM
Help with Bathroom Sink Supply Line RudySands Plumbing 3 02-07-2013 07:46 PM
slow draining bathroom sink jbkenn331 Plumbing 11 12-07-2012 01:13 PM
Wierd problem with non-draining bathroom sink Wife Plumbing 3 02-26-2011 06:25 PM
