SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 04-12-2016, 04:22 PM   #1
Rewards Points: 235
WIfe just sent a pic msg stating she found a slip DRIP DROP leak in the bathroom sink upstairs.
I wont' be home for a few hours..
Am I correct in telling her to simply "tighten" the nut in the pic below to stop the leak?
Regards,
Sean P
SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve?-img_20160410_210904148.jpg
Sean Price is offline   Reply With Quote
Old 04-12-2016, 04:58 PM   #2
Rewards Points: 18,808
Re: SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve?
Those are compression fittings, there was no need for pipe tape. 100% sure it's not leaking under the faucet and running down?
A simple wipe on the supply line to dry it off and use some toilet paper around the line will tell if it's coming from above.
As long as she just turns it a little bit and in the right direction it's not going to do any harm.
If it was mine I'd replace both of those line with flex lines.
Old 04-13-2016, 11:34 AM   #3
Rewards Points: 235
Understood, thanks for this further insight!!
You were correct, the plumbers tape and tightening did nothing...
Will investigate the leak further up... so if it is further up, whats the game plan?
In that pic above how would I should off the water supply off to avoid flooding my upstairs bathroom in case ish hits the fan?
Also how involved is replacing the lines with flex lines, and what is the benefit?
Thanks again,
Sean P
Old 04-13-2016, 03:21 PM   #4
Rewards Points: 3,234
May just need tightening on the faucet end. Easily done with a basin wrench.
As joe recommended, easy fix with two new ss flex lines.
You will have to look for the shutoffs for the sink. If there are none, you will have to turn main water off.
While its off, might as well put on a couple shutoffs if needed. Take off those 90's, get the proper sized shut offs, and screw them on. Add your ss flex line, turn water on, check for leaks, done. Just a suggestion.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
joecaption (04-13-2016)
Old 04-13-2016, 04:41 PM   #5
Someone really cheaped out on that install.
No shutoffs, no escuntion on the drain line.
You need two right angle 1/4 turn valves.
Measure the distance from the valve to the under side of the faucet before buying the flex lines, they come in many lengths.
Buying one to long is not an issue, to short and it's useless.
jmon (04-13-2016)
Old 04-13-2016, 08:51 PM   #6
Retired Moderator
Rewards Points: 7,174
That should be done with TWO wrenches--one on the square fitting (to prevent it from twisting and stressing the pipe going into the wall)
and the second one on the compression nut.
I would recommend putting a bucket under the drip until you get home--just in case the old wall pipe snaps off.
jmon (04-13-2016)
Old 04-14-2016, 11:32 AM   #7
Rewards Points: 198
Pay attention to Oh Mike...he is right on. Be careful and provide support when you are loosening those old fittings.. BTW if you ever have to remove an old threaded pipe from inside a wall, it is best to use two pipe wrenches so you spread out the compression on the pipe that could collapse the pipe. Easy does it. If you are lucky it will come out without problems.
srloren is offline   Reply With Quote
The Following User Says Thank You to srloren For This Useful Post:
oh'mike (04-14-2016)
Old 04-17-2016, 08:35 AM   #8
Rewards Points: 374
Agree with Joecaption. Throw some shutoff valves in there while you're fixing it. Then your family can always shut off the water when they see a leak. You've got plenty of copper to work with there. A pipe cutter, fitting brush and some "push-to-connect" valves would take 15 mins to install...no sweating required (don't forget to shut off and bleed the water main).
http://www.homedepot.com/p/SharkBite...00LF/202270612
costgeek is offline   Reply With Quote
Old 05-27-2016, 12:19 PM   #9
Rewards Points: 235
so I tightened stuff up with the basin wrench, actually was pretty tight as was...
I then dried up everything to a T.. However still a leak but take a look at these pics..
WHAT DO YALL THINK??
I feel it might be coming up from above? Maybe do I need to (re)seal the base around the faucet?
Do I just buy a caulk gun and waterproof caulk and go to town or what?
let me know
Sean P
SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve?-3.jpg   SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve?-4.jpg   SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve?-5.jpg   SLOW Leak/Drip In Upstairs Bathroom Sink Lines, How To Resolve?-6.jpg
Old 05-27-2016, 12:29 PM   #10
Agree with you, probably leaking from faucet itself.
Replace faucet. Those are about 19 dollars at any big box store.
Old 05-27-2016, 01:23 PM   #11
Additionally, I would replace those supply lines as well. If you really feel ambitious, put some push-on angle connector shut offs on those copper supply lines so you never have to turn the whole house water off again for future repairs. Just a suggestion.
It would be under 70 dollars for everything or do it a little at a time. Main thing right now is the faucet with new pop-up assy. That faucet looks like its been leaking for awhile.
Old 05-28-2016, 12:38 AM   #12
Rewards Points: 235
Is there no way to fix or repair this? Must I replace?
Forgive me gentlemen but I come from a different era..where we repaired and repaired as much as possible..
But if not, just let me know!!
oNe
Old 05-28-2016, 12:11 PM   #13
Rewards Points: 767
There is a time and place for repair not replace. 1967 fastback mustang repair,1985 yugo replace. that faucet is the yugo.
r0ckstarr and srloren like this.
ct18 is offline   Reply With Quote
Old 05-28-2016, 01:14 PM   #14
Rewards Points: 198
I always appreciate good advice... and that truly was.
Old 05-28-2016, 01:23 PM   #15
Rewards Points: 198
oNe
That faucet is a cheap piece of crap....replace and sleep at night. You should spray those nuts with WD-40 to help in removing with your basin wrench. I can't tell from the photos but the nuts may be around nylon threaded connections, but I would still use the WD-40.
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
Bathroom sink drains slow, opening and closing stopper will get it to drain fast Arsinek Plumbing 5 05-11-2014 12:30 AM
Help with Bathroom Sink Supply Line RudySands Plumbing 3 02-07-2013 07:46 PM
slow draining bathroom sink jbkenn331 Plumbing 11 12-07-2012 01:13 PM
Wierd problem with non-draining bathroom sink Wife Plumbing 3 02-26-2011 06:25 PM
