Slow Draining Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-31-2015, 02:39 PM   #1
Rewards Points: 38
Slow draining shower
Like the title says, I have a slow draining shower, it's caused by mineral deposits and hair. My problem is, if i try to use CLR or anything like that, it just goes right through, but if dont clean the hairball out of there every week it starts to back up.
I can see that the pipe is about 75% blocked by hard water/mineral deposits. I was wondering if there was a way to hold the chemicals on the deposits to get them to soften/break up.
Unskilled is offline   Reply With Quote
Old 08-31-2015, 03:23 PM   #2
Rewards Points: 3,476
Is it possible to remove the drain cap and snake it. That will work quicker and safer than chemicals. Just a suggestion.
jmon is offline   Reply With Quote
Old 08-31-2015, 03:35 PM   #3
Rewards Points: 6,518
If you could get an inflatable plumber's test plug of the appropriate size beyond the blockage it may have some merit. To dissolve the mineral deposit use the strongest Phosphoric acid your shower materials will tolerate. A visit to a knowledgeable janitorial supply may be necessary for the best.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Unskilled (08-31-2015)
Old 08-31-2015, 04:01 PM   #4
Super Moderator
Gymschu's Avatar
Rewards Points: 558
I'd say that if you're at 75% blocked, it's time for some NEW drain pipes.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 08-31-2015, 04:10 PM   #5
Rewards Points: 38
The snake goes about 18 inches and stops, it usually grabs the hairball(s) and the drain drains fine for about a week.
I was hoping for a cheaper solution, it's not a huge deal to pull the hair out of the drain, just annoying. I may start saving for the repair though.
Old 08-31-2015, 04:53 PM   #6
Snake may contact the trap at about 18 inches.
For hair, two applications of a couple of cups of bleach ( allow to set for 20-30 minutes ) followed by about a half gallon of 160F water usually solves the hair problem. Try a strainer once it's free. Not the perfect solution but lessens the cleaning frequency dramatically.
Unskilled (11-09-2015)
Need help with slow draining bathtub Rav Plumbing 23 12-06-2012 07:07 PM
Slow Draining Basement Bathtub... Pbartender Plumbing 11 10-09-2012 08:53 PM
Slow draining tub mgeller2001 Plumbing 3 07-04-2012 08:15 PM
Strange shower drain installed and draining slowly. Sam1 Plumbing 15 01-03-2012 06:26 PM
Slow draining bathtub IntensitySoftba Plumbing 3 02-20-2011 01:36 PM
