Slip Joint On Bathtub P-trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2015, 11:33 PM   #1
Rewards Points: 187
Slip Joint on Bathtub p-trap
Hello,
for a new bathtub that came with a PVC drain + overflow assembly, which I need to connect to ABS piping, can I use a P-trap with a slip-joint (as seen below)? I would rather use this trap, than gluing it with ABS/PVC cement, as it allows servicing the p-trap more easily down the road due to screwed connections on trap inlet and outlet.
The tub would connect to the slip-joint side of the p-trap. It is a 2" trap in case you need this info.
Location is CA.
Jaxx is offline   Reply With Quote
Old 09-25-2015, 04:50 AM   #2
Retired Moderator
Rewards Points: 7,174
If the fitting is accessible after the installation--then YES---
If you can't get to the trap it must be a glue up
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ddawg16 (09-25-2015), Jaxx (09-25-2015)
Old 09-25-2015, 09:18 AM   #3
Rewards Points: 187
Thanks for the response. Just to clarify, if it is accessible, CAN it be screwed, or does it HAVE to be screwed?
Old 09-25-2015, 10:43 AM   #4
Rewards Points: 777
It can be screwed joint if trap will be accessible.Must be glued if not accessible.
ct18 is offline   Reply With Quote
The Following User Says Thank You to ct18 For This Useful Post:
oh'mike (09-25-2015)
Old 09-25-2015, 06:44 PM   #5
Rewards Points: 1,938
Not a good idea though.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 09-26-2015, 12:25 AM   #6
Rewards Points: 38
The picture is of a 1 1/2" trap, not 2".
SHR Plumber is offline   Reply With Quote
Old 09-28-2015, 09:05 AM   #7
Rewards Points: 777
Most of the homes here in Michigan that i have been in have slip nut traps in the basements.
Old 09-28-2015, 05:09 PM   #8
I just don't like them because if you ever have to rod it you will mess up the seal flange and it will leak. I'm talking the LA nut trap. The MIP is fine.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
Jaxx (09-28-2015), oh'mike (09-28-2015)
Old 09-28-2015, 09:26 PM   #9
Rewards Points: 187
ok, ok, I glued that thing :-)
Thanks everybody for your help!
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 12:37 AM
Would this be a 'P' trap or an illegal 'S' trap? klondiker Plumbing 7 04-06-2012 10:18 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
