Slab On Grade Tub Trap Hole - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2016, 07:54 PM   #1
Rewards Points: 109
Slab on grade tub trap hole
Question- I have a slab on grade with a hole left out for the tub trap. Question is what to do with this depression hole after all plumbing is connected? Insulate it or just insulate the wall cavity?
gwilkrrs is offline   Reply With Quote
Old 01-19-2016, 09:12 PM   #2
Rewards Points: 1,860
Concrete it shut to prevent RADON incursion. Usually a 1 inch layer will work. Fill it up with sand to you only have an inch.
It also stops the nova scotia tunnel rat...
The Following User Says Thank You to Ghostmaker For This Useful Post:
gwilkrrs (01-20-2016)
Shower Trap in concrete slab Jaxx Plumbing 11 10-11-2014 09:52 AM
Slab on grade home gwbossio Building & Construction 2 09-07-2010 09:19 PM
Adding a footing to an existing slab on grade jascox Building & Construction 4 07-05-2010 02:20 PM
conduit in slab grade ugabulldog Building & Construction 4 06-10-2008 08:23 AM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 12:49 PM
