Site Drainage - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2015, 01:55 AM   #1
Rewards Points: 2
Site Drainage
In heavy/long lasting rain, water pools next to our house and seeps into the ground, and then comes out into a lower portion of the house. There is an external pipe/drain that it can flow into, but the angles and size of it must not be sufficent. Also, on the other side of the house, water runs under the house from up the slope, and down into the garage and down our driveway.
I know this is a DIY website, but I am wondering if a general plumber could assist with site drainage, or would there be someone else better to help out?
lsta5838 is offline   Reply With Quote
Old 04-12-2015, 07:21 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,324
Ayuh,.... You need a Landscapin'/ Grade work Pro, not a plumber,....
'bout the only thing they've got in-common is,...
Water flows downhill,....
Old 04-12-2015, 06:24 PM   #3
Rewards Points: 3,448
You need to regrade the land.
Do not have below-grade beds of gravel or mulch up against the house. These will collect water rather than get rid of water.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 04-13-2015, 03:10 AM   #4
Rewards Points: 12
Get rid of all lowspots around foundation make sure your Downspouts are evacuating the water far from the house.
Neosastan is offline   Reply With Quote
This is a how to site, not a why I hate this product site Nathan Roofing/Siding 24 04-08-2020 03:03 PM
Cannot use the site in a meaning ful way. concretemasonry Site Help and Suggestions 3 03-10-2014 04:27 PM
Drainage needs for paver patio RoRoSF Landscaping & Lawn Care 1 05-03-2012 11:06 AM
