Sioux Closet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2015, 11:57 AM   #1
Rewards Points: 261
Sioux closet flange
I bought this Sioux Chief push tite closet flange because I had seen this video made by them. I need to extend it by a few inchs as shown in their video. Problem is, nothing fits. The 3" pvc measures out at 3.040 I.D., the flange is tapered, from the bottom it measures 3.380 O.D. and goes to 3.420 at the top. The I.D. of the flange is 3.080 at the bottom. I wanted to use this flange for the ease of being able to just drop it into my 4" cast iron. Any simple solutions? Thanks TH
thunderhead is offline   Reply With Quote
Old 03-28-2015, 01:49 PM   #2
Rewards Points: 261
OK, got it figured out but can't find a way to edit or delete this post. Thanks
Old 03-28-2015, 09:18 PM   #3
Rewards Points: 247
Please post your solution, it might be helpful to someone in the future. That is the purpose of these forums.
chemman is offline   Reply With Quote
The Following User Says Thank You to chemman For This Useful Post:
mae-ling (04-01-2015)
Old 04-01-2015, 10:45 PM   #4
Rewards Points: 261
Sorry for the delay, I have not used it yet so am not sure it will work. The flange is 3 3/8". I took the gasket off it and put it on a piece of 3" pvc, 3 1/2" OD. Then bought a new flange that is 3 1/2 ID. I tried it on a piece of 4" cast pipe and I can get it inside, it is tight! When I am ready for it I will use some kind of flapper wheel to clean the inside of the cast so it will slide in easier.
The Following User Says Thank You to thunderhead For This Useful Post:
chemman (04-02-2015)
Broken closet Flange Paul8434 Plumbing 2 12-04-2012 07:08 PM
closet flange extension BlueBSH Plumbing 2 09-27-2012 09:58 AM
Closet flange too high dank Plumbing 8 04-14-2010 01:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
