Sinks Leaking And Low Water Pressure Throughout The House - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2016, 08:50 AM   #1
Rewards Points: 4
sinks leaking and low water pressure throughout the house
My water pressure is low everywhere in my house and in the master bathroom i have two sinks with two valves each which are dripping even when shut off, they get worse when I turn on the kitchen sink or any other faucet. I hear a weird squeal when I flush the toilet in the guest bathroom (different bathroom from where the leak is) so basically my entire house has very low pressure and one bathroom has leaky valves all of a sudden. I'm also feeling really sick when using the water for cooking or anything. My house is only 9 years old.
joe4592 is offline   Reply With Quote
Old 01-18-2016, 08:53 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
do you have a well or public water?
WhatRnsdownhill is offline   Reply With Quote
Old 01-18-2016, 08:54 AM   #3
Rewards Points: 4
i have public water
Old 01-18-2016, 08:58 AM   #4
call the town or water company to both take a water sample( since you are getting sick from using the water) and see if the problem is in the street for the low water pressure, they may have had a water main break and dirt or debris may be in the water lines causing leaks in the faucets and noise in the toilet fill valves...
Old 01-18-2016, 10:24 AM   #5
Rewards Points: 18,796
We have no clue where you are so I'll make another guess.
Frozen pipes?
Not going to make you sick but would cause issues with all the plumbing.
Old 01-18-2016, 10:28 AM   #6
Rewards Points: 3,222
Agree with above posts, start there. Determine whether issue is on your side or cities side. Check with neighbors to see if they are experiencing any of the same issues.
If you're getting sick from the cities water, cook and drink with bottled water until it's figured out. Call city immediately and let them know about it. Hope you get it figured out soon.
jmon is offline   Reply With Quote
