Sink Hole Shape Difference - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2014, 02:52 AM   #1
Rewards Points: 4
I have an older sink with a teardrop shaped hole for the center part of the faucet.
The newer faucet I want to put in is a standard circular shape, which means the back of the teardrop, is open.
There has to be a product out there for this situation, but I can't seem to find it.
I don't need to cover the side holes, I will be putting the faucet handles into them, once I figure out the center.
Any help would be appreciated.
grengrad is offline   Reply With Quote
Old 12-28-2014, 03:16 PM   #2
Rewards Points: 1,926
Lot's of caulk? Never seen a sink with a hole like that before.
Old 12-28-2014, 04:23 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,904
What about the old faucet? Is there an escutcheon plate you could possibly reuse?
Old 12-28-2014, 07:21 PM   #4
Rewards Points: 4
Thanks for the replys.
The old faucet was just bigger and longer, it did not have a plate, and I couldn't find any plates that really fit that teardrop shape.
I eventually just gave up and bought a more expensive faucet ($165 ridiculous!) that was ridiculously big, so it would cover the whole hole.
Even with the bigger faucet, the underside washer was only barely larger than the whole, so I had to tape it in place as I tighted the nut into it, so it wouldn't slip, but I finally got it done.
Old 12-28-2014, 10:09 PM   #5
Rewards Points: 1,070
i would be suprised if that doesn't come loose. find a larger washer.
Fix'n it is offline   Reply With Quote
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 02:37 PM
Huge hole behind sink how to cover? CXmandering Kitchen & Bath Remodeling 5 03-07-2012 06:50 PM
Any way to put a 33" wide sink in a 38" wide hole? Natalie559 Plumbing 4 03-05-2012 07:02 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
