Sink Faucet Installation Advice - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By joecaption
Old 11-06-2017, 10:03 PM   #1
Rewards Points: 752
I have a sink that has a faucet on it that is a 3 hole. I want to replace the current faucet with a single hole faucet. I am thinking that there is some sort of plates that you can use that cover the extra holes for purposes such as this? Am I dreaming this or correct?
kennykenny is offline   Reply With Quote
Old 11-06-2017, 10:05 PM   #2
retired framer
Rewards Points: 4,780
Re: Sink Faucet Installation Advice
You should be able to buy one with the new tap, if it doesn't come in the same box.
Nealtw is offline   Reply With Quote
Old 11-06-2017, 10:11 PM   #3
Rewards Points: 752
I acquired the new faucet used(practically new) but has no box or any additional parts. What is the plate called that I am looking for?
Old 11-06-2017, 10:40 PM   #4
jlhaslip's Avatar
Rewards Points: 708
Pretty sure there are "plugs" that will mount into the dead holes.
A real Plumbing Supply House would have them, maybe not a Big Box store.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 11-06-2017, 10:59 PM   #5
retired framer
Look at the bottom front of the spout for a name.
akuhn235 likes this.
Old 11-07-2017, 08:21 AM   #6
Rewards Points: 18,244
We can not see what sink or faucet your talking about without some pictures.
Is it a kitchen, or bathroom faucet?
With the right faucet to do a retrofit the base would be wide enough to cover up those old holes.
Old 11-07-2017, 07:14 PM   #7
Rewards Points: 1,564
https://www.homedepot.com/b/Plumbing...s/N-5yc1vZbqjs
Looky here.
Ghostmaker is online now   Reply With Quote
Old 11-15-2017, 10:50 PM   #8
Rewards Points: 126
They are usually called an escutcheon or a deck plate. As others stated, you will want to locate manufacturer and model number to get one that fits correctly. Best bet is to reach out to manufacturer to verify what model you have and have them set you up with the correct escutcheon/deck plate.
Cheers,
AK
akuhn235 is offline   Reply With Quote
Mop sink, 3-bay sink, only one floor drain - help? summersab Plumbing 9 07-30-2017 01:39 PM
Installing bathroom faucet onto vessel sink lrriley Kitchen & Bath Remodeling 0 02-12-2016 04:58 PM
Looking for advice re low flow from shower cold faucet Rav Plumbing 4 12-12-2015 09:17 AM
Double Basin Concrete Sink leaky faucet newoldhouse Plumbing 3 05-14-2012 11:25 PM
Under sink filtration install problem? Water comes out faucet side when disposal on sprtfan Plumbing 16 08-17-2010 11:13 PM
