Sink Drains/p-trap? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By joecaption
Old 11-21-2016, 07:46 AM   #1
Rewards Points: 290
Sink drains/p-trap?
I didn't think I'd have to ask this question, but after getting to the Home Depot I wasn't overwhelmed.
I rain 1.5" PVC through the wall for my plumbing rough ins. Now it's time to think about going from the rough in to the sink.
They have P-trap kits, which seem to offer compression fittings that make it look like an easy install, but the plastic looks awfully flimsy.
Then there's PVC p-traps: some seem to have a little nipple on the bottom, and others have a screw-on connection on one end and glue-on female end on the other.
What is the proper P-trap to use?
gizzygone is offline   Reply With Quote
Old 11-21-2016, 11:23 AM   #2
Breakin' Stuff
Rewards Points: 1,374
Re: Sink drains/p-trap?
I'm curious about this as well. The PVC is much sturdier but I would prefer compression fittings in case I ever want to remove the trap (like if I drop something down the sink).
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 11-21-2016, 01:34 PM   #3
Rewards Points: 18,772
Use the compression style, it will work fine and be easy to get off to clean out the drain and trap.
Only one I've seen break is when it froze.
SHR Plumber likes this.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Bret86844 (11-21-2016), SHR Plumber (11-21-2016)
Trap leak when sink is full Zamboknee Plumbing 9 11-04-2014 11:40 PM
Trap help for bathroom sink Trucon01 Plumbing 8 04-14-2014 05:00 PM
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 02:37 PM
Swivel PVC P trap for bathroom sink. pinecone12 Plumbing 9 06-06-2011 09:14 AM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
