Sink Drainage Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2016, 09:37 AM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 162
Re: Sink Drainage Issue
Originally Posted by Ghostmaker View Post
Just a small question. Did your current strainer have ports for the overflow drain? Some strainers are made for bar sinks and do not have the drain ports for the overflow.
I agree that this is the problem.
Old 04-10-2016, 11:30 AM   #17
Property Mgt/Maint
Rewards Points: 8,184
OP said the line once drained fine. Maybe they are blocked.
Easy enough to test. Use a funnel and pour water into the overflow drain hole. If you don't see the water flowing steadily into the drain tube then there is a blockage somewhere in the overflow run.
Originally Posted by jeffdoesrepairs View Post
That is something I can check out, however this drain drained fine when I moved in. -Jeff
I have had great luck with this product.
Originally Posted by Yodaman View Post
http://www.efaucets.com/detail.asp?P...FZdZhgodPOcFqw
I would try a industrial liquid drain cleaner first.
Yodaman is offline   Reply With Quote
Drainage issue while installing my new RO system. EvanWells Plumbing 4 10-25-2015 09:16 PM
poor drainage from bathroom sink JKeefe Plumbing 5 08-13-2015 07:33 PM
Drainage issue w/ townhome 0sevenjk Landscaping & Lawn Care 17 03-16-2011 10:00 AM
Drainage Issue In my Lawn kirridam Landscaping & Lawn Care 7 05-31-2009 03:05 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
