Sink Drain Tail & Trap Repair - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 2 Post By ZTMAN
  • 1 Post By joecaption
  • 1 Post By JBG420
  • 1 Post By JBG420
Old 08-09-2017, 01:27 PM   #1
Rewards Points: 46
Another plumbing issue. Kitchen sink was leaking from a glued/solvent weld trap. It's a double basin sink so I cut the whole trap off at the wall. The trap is completely clogged. Also, the drain in the wall is completely clogged. I dug out as much crap as I could but there is still a lot in there and who knows how much after the elbow inside the wall. Any way to clean this out? Flush it thru with water from a hose Maybe?
Also, the metal tailpiece from the one sink appears to have broken. Not sure what i need to get to replace that. Thanks for the help.
PS I already went out an bought 1.5 pipe to glue together for the trap.
Sink Drain Tail & Trap Repair-20170809_141950_1502303170496.jpg   Sink Drain Tail & Trap Repair-20170809_142000_1502303206519.jpg
JBG420 is offline   Reply With Quote
Old 08-09-2017, 01:31 PM   #2
retired framer
Rewards Points: 15,046
Re: Sink Drain Tail & Trap Repair
This will help with the basket. You just need a new tail piece.
Old 08-09-2017, 03:18 PM   #3
ZTMAN's Avatar
Rewards Points: 620
I wouldn't be flushing with a garden hose if its that clogged. Would most likely get a face full of nasty.
I would try a snake first to see how bad the clogged is packed in.
Dave Sal and Nealtw like this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 08-09-2017, 05:26 PM   #4
Rewards Points: 18,952
Made a bigger mess for yourself by cutting off that line so close to the wall.
Should have left about 2" sticking out to glue on a trap adapter.
http://www.homedepot.com/p/1-1-2-in-...2114/100348180
Loose all that old chrome pipe and use all PVC.
About a $15.00 fix to replace it all.
Behind that wall is likely a tee, make sure when snaking it out the snake goes down not up.
Nealtw likes this.
Old 08-09-2017, 05:33 PM   #5
Rewards Points: 46
Thanks. Can't see from the picture but the drain pipe is sticking out of the wall a good 2 inches. There was a coupler right where I cut so didn't have a choice.
What you linked will attach right to the drain basket?
Old 08-09-2017, 05:54 PM   #6
retired framer
You need a kit like this.
https://www.rona.ca/en/double-sink-i...on-kit-1236078
The link that Joe linked to was the piece that goes on the end of the pipe coming out of the wall. If you have black ABS, then buy that part in ABS so there is no question on glue and that would be the only piece that gets glues.
Next time you have this problem You can just unscrew everything.
Old 08-09-2017, 06:13 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 240
Rent a 3/8 cable to clean the drain. Then purchase:
an end outlet continuous waste kit,
1.5" ptrap
1.5" trap adapter.
Also get a flanged DW tailpiece to replace your existing one.
Also grab a double end flange tailpiece just for giggles- might need it.
You'll need glue and primer for the trap adapter too
All this will be plastic parts and compression nuts
Good luck
Old 08-09-2017, 06:42 PM   #8
Rewards Points: 46
Thanks a lot guys. Great forum and appreciate the help.
Nealtw likes this.
Old 08-10-2017, 08:02 AM   #9
Rewards Points: 46
Got some pipe and have 2 questions.
You can see in my picture that on that right drain, the DW line connects at the "back". On the new telescoping continuous drain kit, the DW drain connection is on the side and I have a pretty tight clearance. DW line will have to make a tight 90 to connect. Any issues with that?
Also, new sink drain tail pieces are flanged. Do i need washers between those connections given the flange?
Sink Drain Tail & Trap Repair-20170810_090820_1502370520912.jpg   Sink Drain Tail & Trap Repair-20170810_090820_1502370553677.jpg
Old 08-10-2017, 09:55 AM   #10
Rewards Points: 46
So here's what I did - cut a new hole in side of cabinet in order to move DW drain line to line up with connector on drain pipe. Filled both sinks up half way and dumped them - no leaks. I also have no washers between drain tails connecting to sink baskets. That ok? Guess so if it isn't leaking.
Nealtw likes this.
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
Can bath sink and service sink drain into 1.5" branch drain hammerlane Plumbing 29 11-16-2012 02:37 PM
Old Basement Sink Drain - Clay? maybere Plumbing 7 09-27-2011 11:49 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
