Sink Drain And Sink Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2016, 08:57 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 240
Sink drain and sink install
When installed the drain of a sink, what do I use for a sealant??? I use to use plumbers putty but now I hear you don't use it on the drain.
Also , what adhesive do I use when mounting a sink top onto a bathroom vanity
Barry
Barry J is offline   Reply With Quote
Old 05-10-2016, 09:07 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 170
Re: Sink drain and sink install
Putty is fine unless you have marble, granite or cultured stone- then I'd use silicone
Old 05-11-2016, 06:13 AM   #3
Rewards Points: 18
For the sink top to the vanity I use caulk. Most caulks have adhesive properties but I prefer Dynaflex.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Condensate Drain Line Mystery FrogFan HVAC 5 09-24-2015 09:27 PM
Venting a new sink drain install BaconK5 Plumbing 11 02-19-2015 04:30 PM
Easiest way to install utility sink for washer to drain into? iammikeDOTorg Plumbing 9 02-09-2014 04:19 PM
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
