Sink Arbitrarily Fills With Smelly Water. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2015, 03:11 PM   #1
Sink arbitrarily fills with smelly water.
Hello. I need help diagnosing a problem with my kitchen sink. I just began renting this house about a month ago, and side then we've discovered a number of flaws, including a history of water damage from extended water disconnection before we got here.
Back to my problem... My nephew and I were chipping paint today when he noticed that the kitchen sink was filling with water that smelled like sewage. There wasn't any water running anywhere in the house. Nowhere. Not being very literate with plumbing, I tried to twist a couple knobs under the sink - hoping that one might cut off whatever flow of water was coming out. Surprisingly, it actually did cause the water to begin to slowly drain. The thing that really puzzles me about all this though is that there was not a single bit of water running in the house - much less in the kitchen.
Other possibly relevant info:
-We've has a slow drain in that kitchen sink for awhile. Furthermore, we have a leak under the sink in the cabinet if we run the water on the side of the garbage disposal (which doesn't appear to be functional). When we run the water on the garbage disposal side, it tends to back up on the other side, but not on the garbage disposal drain. When the sink randomly backed up today without any water running, it came from both sides, but predominantly the non-garbage disposal side.
-The landlord's "handyman" tried to address the slow drain yesterday, but I was under the impression that he ultimately made a diagnosis and deferred any actual repairs until later.
Is this a local plumbing issue or did the city lines just back up into our sink? Because I don't see why the drains would do that 45 minutes after our most recent water usage. We weren't even running the washer or dish washer. Also, the water coming OUT of the faucet should still be safe, right?
Thanks advance for any help. This house has been stressful enough without sewage-smelling water invading unannounced. I really want to resolve this quickly.
beatmixer16 is offline   Reply With Quote
Old 01-19-2015, 03:21 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not a typical problem and should be addressed by the owner immediately. Sanitary sewer water can harbor all kinds of serious diseases and isn't anything to play around with.
XXX
Old 01-19-2015, 05:10 PM   #3
Retired Moderator
Rewards Points: 7,174
Is this a two story house?
Old 01-19-2015, 05:20 PM   #4
No, it's single story.
Old 01-19-2015, 05:51 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 290
beatmixer- I moved this to the plumbing board. We have a few real good drain guys here that might be able to offer some ideas.
Oh, and welcome to the chatroom
Old 01-19-2015, 05:59 PM   #6
Rewards Points: 3,492
It is possible that a clogged city main sewer line/manhole can cause a back up. As mentioned, not very likely. If there is no backflow preventer installed on the house sewer line it could cause lower level sinks, toilets, etc. to back up. I've seen this. However, the entire neighborhood would be affected.
If it continues, definitely have the landlord address it as soon as possible. I'm thinking more of a partial blockage somewhere. Kitchen sink lines with garbage disposals are notorious for clogs. You mentioned this is the only place where it happens.
Yes, the water coming out of your faucet is safe.
Others will be along with more advice/suggestions.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
oh'mike (01-19-2015)
Old 01-19-2015, 06:32 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 32,008
Sounds like the drain was backing up. There must be a clog somewhere in the main line.
Old 01-19-2015, 06:42 PM   #8
Thanks guys - especially Eplumber. The landlord said he's booking his guys to deal with it. I guess we'll see..
The Following User Says Thank You to beatmixer16 For This Useful Post:
jmon (01-19-2015)
Old 01-20-2015, 07:16 AM   #9
Rewards Points: 3,436
Note that the control valves under the sink are redundant shutoffs for the hot and cold fresh water. (You use them so you can take apart the faucets to replace washers, cartridges, etc.)
Drains do not have manually operated control valves.
It is only coincidental that the sink started to drain out while you were fidgeting down below.
Are the neighboring houses uphill from you?
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 01-20-2015, 08:26 AM   #10
Super Moderator
Gymschu's Avatar
Rewards Points: 558
Very wise move to get your landlord involved. Trying to do all the work yourself without nofying the landlord can cause you to be liable for any damages caused by your work. On the flipside, some landlords could care less about their tenants and would allow a problem like that to fester.
Old 01-20-2015, 09:17 AM   #11
@ AllanJ, yes. There is a significant grade to one side.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
No Hot Water at Kitchen Sink sirrus3610 Plumbing 8 06-17-2013 04:28 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
