Shut-off Valves With Scale Buildup Leak But Re-seal? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2016, 07:30 AM   #1
From Philadelphia
Rewards Points: 291
Shut-off valves with scale buildup leak but re-seal?
I've noticed this in the past and have noticed this recently too. A globe/gate valve has scale buildup (near a leaking packing nut). I tried tightening the packing nut but it wouldn't budge. The valve still leaked small slow drops, even after a few days. But I noticed after a few weeks, this leak was non-existent. Have you ever noticed this? Is this because the minerals/scale in the water have essentially plugged the leak?
hellohello is offline   Reply With Quote
Old 02-18-2016, 07:35 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
yes, but they sell packing material that with the valve shutoff, you can take the packing nut off and put more packing in and then tighten the nut back down...leak fixed..
WhatRnsdownhill is offline   Reply With Quote
Old 02-18-2016, 09:05 AM   #3
Rewards Points: 18,806
Any time I can I replace or add a ball valve in the line.
That style valve is always going to be trouble.
Very common for then to not shut completely off or even have the stem break off.
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Toilet Seal Leak Problem boblgamble Plumbing 4 06-21-2008 10:42 AM
Slow leak from shut off valve Topdog Plumbing 12 06-05-2008 12:02 AM
Help with water main seal leak! Taipans Building & Construction 2 03-18-2008 08:06 PM
