Showers Don't Get Hot Enough - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
Old 09-26-2018, 07:05 PM   #16
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,070
Re: Showers don't get hot enough
Originally Posted by h22lude View Post
...an adjustment within the mixing valve to let in more or less hot water.
pressure balancing. that video is supposed to describe it
Old 09-26-2018, 07:13 PM   #17
Guapo
Rewards Points: 11,950
I guess that I missed part of the thread. I have a Symmons Temptroll. The hot water setting is similar. You can't have the on/off valve opened all the way when you loosen the stop screw. If you do, there won't be enough room to adjust it so only turn it on half way. Then open the stop screw a few full turns & turn the valve the rest of the way. In my case, the hot water tanks are in another building so I have to deal with temperature drop. At 9AM no matter how I adjust it, it won't be as hot as it will be at noon. I want it to be scalding. I can lessen it, if needed.
Nealtw likes this.
Guap0_ is offline   Reply With Quote
Old 09-26-2018, 07:24 PM   #18
Guapo
I could be wrong but it sounds like Guap0 is talking about something different from the stop limit. Stop limit allows the handle to be turned more. Sounds like Guap0 is saying there is an adjustment within the mixing valve to let in more or less hot water.
Actually, the stop limit & the hot water setting are sometimes one in the same. That's why I hate when the hot water setting & the stop limit are one in the same. If you are rebuilding your shower, always buy a Hans Grohe shower body that remembers the temp setting of your last shower. It's $600 but worth every cent.
Old 09-27-2018, 01:38 PM   #19
Rewards Points: 4,072
Maybe you should look up hot tub temperatures.?
ron45 is online now   Reply With Quote
Old 09-27-2018, 01:46 PM   #20
Rewards Points: 583
100F, with 104F being the highest recommended. Average shower temp is 105F, with 110F being the highest recommended. How is this related to my problem?
h22lude is offline   Reply With Quote
Old 09-27-2018, 03:32 PM   #21
I don't know about you but in a hot tub I can't stand no more then 101*
How hot do you need a shower to be.?
Old 09-27-2018, 04:50 PM   #22
Rewards Points: 583
This is also with water all around you constantly being heated. Shower water is not heated once it leaves the hot water tank and it cools down pretty quickly as it falls from the head. Get the shower to the temp you like, I bet you will find it to be slightly hotter than a hot tub.
In any case, to answer your question I don't know what temp I like but I know it is hotter than my shower at 99F.
Old 09-27-2018, 08:09 PM   #23
Rewards Points: 1,258
Crank up your hot water tank a bit. Stay below 140 at the tank.
Old 09-28-2018, 06:58 AM   #24
Rewards Points: 583
That seems like a bandaid. Doing that would make my sinks very hot which isn't good with a toddler.
Old 09-28-2018, 08:01 AM   #25
Super Moderator
joed's Avatar
Rewards Points: 23,072
It likely won't help if the faucets a pressure balanced.
Old 09-28-2018, 12:10 PM   #26
Rewards Points: 715
Shut the cold water off at the showers and then check the temp of the hot water coming out. It maybe mixing cold water into the hot side.
ct18 is offline   Reply With Quote
Old 09-28-2018, 12:14 PM   #27
Rewards Points: 583
Which would mean I need a new cartridge?
I'll have to find the shut offs. Not sure where they are.
Greenboard, Showers and Hot Mop ddawg16 Drywall & Plaster 3 06-11-2013 05:58 PM
1 year old house, all showers luke warm meets1 Plumbing 12 10-19-2012 05:44 PM
Insulating wall between showers .. vapor barriers? RICKM15752 Building & Construction 6 08-21-2011 12:04 PM
Shower bench tile poped out after 3 showers!!??? N313 Tiling, ceramics, marble 7 08-06-2011 04:10 PM
why does my water not get hot in both showers? doreen28 Plumbing 3 03-27-2011 07:47 AM
