Shower Water Line Vibrates - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2015, 01:55 PM   #1
Rewards Points: 972
Shower water line vibrates
For some reason the few weeks our 2nd floor shower seems to pulse/vibrate for a while when turned on. We've lived in the house for about 8yrs and it never really did this before. There are a few times I can recall it acting this way for a moment when the toilet was flushed, but it'd go away quickly. Now it seems like it does it almost every day when the water is turned on, it stops if you turn the water fully on and then back it off.
For what it's worth, most of the house is PEX, but the line going to the 2nd floor that supplies the shower and toilet are copper. I'm guessing this is a water hammer effect, but not sure why it started, nor how I can make it go away.
Master Brian is offline   Reply With Quote
Old 07-07-2015, 02:17 PM   #2
Rewards Points: 18,976
Remove the shower head and replace it or let it soak in some CLR.
Old 07-07-2015, 03:20 PM   #3
Rewards Points: 972
Ill give that a try. Thanks!
Old 07-07-2015, 07:18 PM   #4
Retired Moderator
Rewards Points: 7,174
If that doesn't work, change the cartridge in the mixer valve.
Old 07-08-2015, 03:55 PM   #5
Rewards Points: 972
I'm willing to bet if that's the case, the cartridge is the issue. The shower head seems fine and doesn't appear to be clogged, but about the time this started happening it also seems that I can't turn the valve up as high without getting extremely hot water. (i.e. Before to have 'normal' hot water, I'd turn the valve 3/4 of the way on, now if I turn it half way it's too hot. Haven't changed the setting on the Hot Water Tank.
Old 07-08-2015, 05:00 PM   #6
Special User
Rewards Points: 1,230
Sounds like the pressure balancer in the valve is kaput.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
oh'mike (07-09-2015)
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
