Shower With Varying Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2016, 01:45 PM   #1
Rewards Points: 684
Shower with varying pressure
Hey all, lately our shower has had inconsistent water pressure and it never used to be like that. The faucet is almost 6 years old and this is an area with hard water, although we do have a water softener.
I assume I need to replace something in the faucet but I'm not sure how far I need to go. It's a Delta T17030 and the cartridge is on the expensive side. There is something called a "cartridge adapter" that is much more affordable:
https://www.deltafaucet.com/parts-pr...Number=RP46073
Do you think this could be the problem or do you think I need to look into replacing the entire cartridge?
Thanks!
Richo is offline   Reply With Quote
Old 10-07-2016, 03:28 PM   #2
ZTMAN's Avatar
Rewards Points: 604
Re: Shower with varying pressure
If you think the cartridge is gummed up, take it out and soak it in some CLR. Do the same with the shower head. That will just cost you some time and a little CLR.
If that doesn't work, call Delta and get a free cartridge, they are guaranteed for life
ZTMAN is offline   Reply With Quote
The Following 2 Users Say Thank You to ZTMAN For This Useful Post:
Ghostmaker (10-07-2016), Richo (10-08-2016)
Old 10-07-2016, 04:19 PM   #3
Rewards Points: 684
I did soak the shower head a while back and it didn't make a difference, so I will give that a try with the cartridge. Thanks for the info on Delta.
We have Lime-Away. Will that work as well as CLR?
Old 10-07-2016, 05:55 PM   #4
ZTMAN's Avatar
Rewards Points: 604
Never used lime away, give it a shot and see.
Ultra high shower pressure carlk4574 Plumbing 1 03-14-2013 08:03 PM
Low hot pressure to power shower lazthemag Plumbing 2 02-21-2010 09:35 AM
Low Water Pressure Delta Single Handle Shower Model 602 rckeagle Plumbing 2 07-24-2009 02:11 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 05:27 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
