Shower Valve Trim Kit Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2017, 08:19 AM   #1
Rewards Points: 92
Probably a stupid question but a Google search came up empty so I thought Id ask here.
When purchasing a "Shower Valve Trim Kit" does the valve come with that kit or is this a separate purchase?
PappyO is offline   Reply With Quote
Old 09-26-2017, 08:58 AM   #2
retired framer
Rewards Points: 15,536
Re: Shower Valve Trim Kit Question
You have to buy one of each.
The Following User Says Thank You to Nealtw For This Useful Post:
PappyO (09-26-2017)
Old 09-26-2017, 10:47 AM   #3
Rewards Points: 92
Thanks........another sub question: Do you have any knowledge of Signature Hardware........they have some very good pricing on trim kits although I've never heard of any on the MFG's like (Trimble, Oxford, Glenley etc)
http://www.signaturehardware.com
Old 09-26-2017, 10:49 AM   #4
retired framer
Can't help with that but others might
Old 09-26-2017, 05:54 PM   #5
Rewards Points: 1,942
Be advised that any faucet you purchase over the internet that is used for drinking. Kitchen and bar and lavatory faucets you will need to prove they meet California lead standards. That is state wide now.
Under IPC that controls 35 states you will need tub or shower valves that are certified to meet ASSE 1016/ ASME A 112.1016 /CSA B 125.16 or ASME A112.18.1/CSA B 125.1 Lead standards do not apply for these.
You can use under IPC a two handle faucet on a tub without a shower but you must install an ASSE 1070 tempering vale to prevent scald.
The other major thing to consider is Parts availability 10 years down the road.
Moen Delta they will be there. Signature your guess is as good as mine.
Old 09-26-2017, 06:59 PM   #6
Rewards Points: 114
If you're going cheap get yourself a Delta, Kohler or Moen (not the Positemp) valve. Those companies make decent valves and a pretty inexpensive price and they do have some higher end lines. You can get a quality body and trim kit with a lifetime warranty for $250ish.
If you really want something that looks nice check out Rohl. It probably looks similar to what Signature Hardware is selling but is the real stuff. Looks nice, lasts, works great, feels solid and they stand behind it. A basic shower is probably around twelve hundred though for a thermostatic valve, volume control, arm and head.
2x_Tom is offline   Reply With Quote
Old 09-26-2017, 08:18 PM   #7
Rewards Points: 282
when you say valve you mean and trim kit combined correct?
Kemper100 is offline   Reply With Quote
Shower Valve Trim Kit patelhe Plumbing 0 10-24-2016 12:35 PM
single valve shower question mikem201 Plumbing 3 02-14-2013 06:07 PM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 10:05 PM
Shower Valve Question ccredsox Plumbing 3 02-06-2012 11:43 AM
