Shower Valve Jammed - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2011, 04:50 PM   #1
Cool
Shower valve jammed
plumbing problem
I am dealing with a Stanadyne/Moen tub/shower valve that is jammed. I can't pull it out to turn on and it will not rotate left or right. Can this condition be fixed by replacing the cartridge? or is it a complete valve replacement?
f stansbery is offline   Reply With Quote
Old 07-03-2011, 04:53 PM   #2
Retired Moderator
Rewards Points: 7,174
Should be a cartridge will fix that--be sure to use a Moen cartridge pulling tool--
clean and polish the inside of the valve body before installing the new cartridge.---Mike----
plumberinlaw (07-03-2011)
Old 07-04-2011, 01:28 PM   #3
Shower valve jammed
Thanks for the reply Mile!
The Following User Says Thank You to f stansbery For This Useful Post:
oh'mike (07-04-2011)
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 15 07-04-2020 01:12 PM
shower valve weirdness wombosi Plumbing 2 06-26-2010 02:59 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 04:37 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Need help replacing shower diverter valve magnolia Plumbing 9 07-12-2008 09:54 PM
