Shower Valve Handle Set Screw Jammed - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2016, 08:17 AM   #1
Rewards Points: 88
Shower Valve Handle set screw jammed
Hope you all can give me some insight. Tennant called and said the handle from her shower keeps falling off (I just purchased the property this summer). Taking a quick look the other day while I was out there I see there is a set screw on the inside of the handle that appears to tighten against a valve stem extension... however I'm just guessing. I know there is a set screw on the outside of the handle and one inside. Here are my questions:
1) Does anyone know what kind of valve this is? It's old and heavy. I don't see any manufacturer.
2) Do you think that set screw on the outside of the handle separates the handle in two pieces so you can reach the inner set screw?
3) If the design is how I'm thinking, I suspect that valve stem extension is probably corroded into the handle. I can probably get it out, but how would I affix it to the existing valve stem mounted to the fixture?
4) Lastly, do I have this all wrong?
I appreciate any insight. Thank you!
Shower Valve Handle set screw jammed-faucet1.jpg   Shower Valve Handle set screw jammed-faucet2.jpg   Shower Valve Handle set screw jammed-faucet3.jpg   Shower Valve Handle set screw jammed-faucet4.jpg
snooger is offline   Reply With Quote
Old 03-08-2016, 08:34 AM   #2
JUSTA MEMBER
Rewards Points: 3,992
The inner part is an adapter to allow the outer jewelry to attach.
Use some penetrating oil type stuff to release the set screw, take them apart, reinstall the adapter tighter, then the outer and you are done.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
gregzoll (03-08-2016)
Old 03-08-2016, 08:38 AM   #3
SHEPLMBR's Avatar
Rewards Points: 178
Looks almost like a Moen Monticello, but the stem/hub doesn't look right for it.
SHEPLMBR is offline   Reply With Quote
Old 03-08-2016, 09:30 AM   #4
Rewards Points: 88
Thanks both of you. Yes I was thinking about the penetrating oil, but didn't want to bug the tennant without a solid plan. So, the set screw inside that handle releases a small hub that attaches to the valve stem? How does that hub attach? I see a ridged area for grip, but I see no way the handle won't pull back off. Is that hub just too deep in the handle and that set screw should be hitting the shoulder of the valve stem (towards the wall past the ridged section)?
Old 03-08-2016, 09:38 AM   #5
JUSTA MEMBER
your bottom picture appears to have a wear ring near the end, that is where the inner set screw has been seated, and is now loose.
ED
Old 03-08-2016, 09:50 AM   #6
Rewards Points: 88
ED
That makes sense to me. That inner set screw is a PITA to get to. Does that outer set screw take apart the handle so I can get to the inner one?
Thanks again
Old 03-08-2016, 10:55 AM   #7
JUSTA MEMBER
Yes.
The outer screw releases the outer housing from the inner adapter.
the inner adapter screws tight to the stem, then the outer housing screws to the adapter.
SIMPLE mechanics, Many universal faucets have a similar setup to fit many applications.
ED
Old 03-08-2016, 12:20 PM   #8
SHEPLMBR's Avatar
Rewards Points: 178
Almost looks as if there is a spline adapter of some sorts missing.
mixet shower valve temperature handle spins round n round pman6 Plumbing 12 02-12-2014 09:39 PM
Best PEX tubing size for shower valve? Studly Plumbing 4 05-22-2013 06:53 PM
Shower Valve Assembly/Locking Nut rookie49 Plumbing 11 01-10-2013 11:14 AM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Shower valve jammed f stansbery Plumbing 2 07-04-2011 01:28 PM
