Shower Valve Caulk Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2015, 11:05 AM   #1
Rewards Points: 126
Hey everyone!
I know there is some debate whether to caulk around the shower valve escutcheon, but I decided to caulk around it, leaving a "hole" at the bottom, with clear silicone.
My question is should I caulk the escutcheon screws as well? It seems like water could potentially get behind them since there's no gasket, grommet, o-ring behind the screw head. Problem with caulking them is it might be a booger trying to ever get them back out.
What do you think?
Thanks!
TeeRiddle is offline   Reply With Quote
Old 12-29-2015, 11:23 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
What do you think?
Ayuh,..... I think, yer Over-thinkin' it,.....
Find another project to play with,... yer done there,....
The Following User Says Thank You to Bondo For This Useful Post:
oh'mike (12-29-2015)
Old 12-29-2015, 05:48 PM   #3
Rewards Points: 1,414
Don't caulk them. The only situation where I'd even think about it would be if you had an extra showerhead aimed *at* them, for example. Otherwise it's overkill and you risk making them harder to take out and making them look like an amateur job.
Tom738 is offline   Reply With Quote
Old 12-29-2015, 05:52 PM   #4
Rewards Points: 1,852
Your done good job move on...
Shower caulk. Second contractor. Am I getting honest answers? fuzzbutter General DIY Discussions 13 11-02-2014 01:01 PM
Shower Valve & Head Depth 325_man Plumbing 6 07-11-2014 08:41 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 10:05 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 10:09 PM
