Shower/Tub Faucets Not Working Correctly - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By joecaption
  • 1 Post By clarenceboddick
  • 1 Post By Ghostmaker
Old 12-04-2016, 05:03 PM   #1
Rewards Points: 50
Shower/Tub faucets not working correctly
Hello friends,
I hope everyone is enjoying the weekend. As you know, I recently purchased a home.
It is an older home, about ~10 years old, so it needs some work.
In one of the bathrooms, when I turn on the shower, the water from the bottom spout (the one that fills the tub) continues to pour.
I have raised the lever on that spout, which should divert the flow completely to the shower, but it does not.
See pics below.
I presume some part(s) need to be replaced, or maybe it is a plumbing issue, or both?
Can someone please guide me?
Thank you very much,
Oxonian
oxonian is offline   Reply With Quote
Old 12-04-2016, 06:13 PM   #2
Rewards Points: 18,796
Re: Shower/Tub faucets not working correctly
Just replace the spout with a new one.
Look on the bottom of it to see if there's a hole in the bottom, if so there's a set screw that needs to be backed out to remove it. (could be metric)
No hole then it needs to unscrewed, facing it, lefty loosey.
oxonian likes this.
oxonian (12-04-2016)
Old 12-04-2016, 10:26 PM   #3
Rewards Points: 50
Thank you joecaption, I appreciate it.
Is there a particular size of spout I need, or are they pretty much standard?
I took a look at the website of a big box store, and it seems that there are numerous tub spouts with diverter for $15-20.
Are there any brands which are better? I will put this in the guest room, so if I am replacing it, then I might as well get a nicer one.
Do I need to turn of the water supply when I change the spout?
Sorry for the basic questions, I am grateful for your help.
Oxonian
Old 12-07-2016, 08:01 AM   #4
Rewards Points: 1,054
I'd just pull out the diverter plate from the faucet and check the rubber gasket.
I prefer to install faucets so they can withstand being used as a shaving shelf. I use a threaded brass shower socket mounted stoutly to wood. I use a brass threaded pipe that is the proper length so that the faucet tightens up snug to the tile when square. There should be no flex or play in the faucet, even when stepped on. I don't use plastic faucets.
oxonian likes this.
clarenceboddick is offline   Reply With Quote
The Following User Says Thank You to clarenceboddick For This Useful Post:
oxonian (12-15-2016)
Old 12-07-2016, 07:33 PM   #5
Rewards Points: 1,866
Moen will send you that new tub spout give their warranty number a call.
1-800-289-6636
oxonian likes this.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Creating a working space helpinggirl General DIY Discussions 10 11-14-2012 08:18 PM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 06:23 AM
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 09:28 PM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
Wiring of my two-zone system not working correctly AMontemagni HVAC 3 01-27-2007 12:07 PM
